ElijahBrookes
Upload Speed
I've not been getting any upload speeds for days now, it sits at around 0-0.3 mbps which is ridiculous. I've done all the resets and tests I could do and reported this issue multiple times now with nothing getting me closer to a result. My partner lost a whole day's worth of work after it didn't sync sue to this issue aswell. Please do something about this as I will be changing my broadband provider otherwise.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Upload Speed
Can you please
