Snacktapus
  • 5
Message 1 of 8
Upload Speed very slow - 2.5 mbps???
Hi there,
My upload speedtest.net on a wireless connection consistently comes through at 15-16 mbps (currently on the M200 package) - however when I try to set up a live stream in OBS I only get 2-3 mbps, why would this be? I have tried at different times of the day and it doesn't make a difference. As a result my live stream is jumpy and not great at all.
Can anyone help? Why would the speedtest give me a much higher reading?
Steve
om_spencer
  • 70
Message 2 of 8
Re: Upload Speed very slow - 2.5 mbps???
Can you do a speed test over lan to rule out it being wifi that's the issue.
Secondly are using the hub 3.0.
Thank you
Toj_H
  • 41
  • 5
  • 5
Message 3 of 8
are you using wifi?
a wired connection is always best.
You could try and pin hole resetting your hub.
Snacktapus
  • 5
Message 4 of 8
Yes will do a lan test tomorrow - waiting on a cable. It is the Hub 3.0 that I am using.
Why would the speed test pick up a higher upload speed over wireless though? The wireless speed test was 15 mbps but the reality was just a 2 mbps upload speed? Is there some sort of limiting?
Thanks all
Snacktapus
  • 5
Message 5 of 8
Upgraded to M350 - upload speed on the speed test still really poor at 8mbps
Also tested on a wired connection and still only getting 2mbps on OBS?
Tried resetting the router midweek and no improvement?
Snacktapus
  • 5
Message 6 of 8
Ran another speed test this morning on a wired connection and upload speed around 20 mbps - yet when I run OBS I still only get 2.5 mbps?
Is the connection being throttled?
josh94
  • 29
Message 7 of 8
I am getting 520mbps down - and 1.7-3mbps up - no issues apparently 🙂 🙂 🙂 🙂 🙂
Alan79
  • 30
Message 8 of 8
In OBS, have you checked to make sure you're set to use the correct bandwidth?
File > Settings > Output
Then under Bitrate, you ideally want it set to 6000 Kbps.  It looks like you're getting the upload bandwidth (I'm stuck with 1-2 Mbs during most of the day!).
