antbates91
  • 6
Message 1 of 10
Upload Speed / Packet loss
I've not long had Virgin Media installed, around about 2 weeks. I've notice from day one that there have been a few issues with the upload. Download side of things, everything is fine.
I rarely ever get the full 35Mbps upload, it normally hovers around 28 tops, but tends to fluctuate between 15 - 28 mostly. Another issue I notice is random stalling when I request a webpage. It can last for around 20 seconds, then everything returns to normal. It's not related to specific websites, its just random.
I am using a hub 4 in modem mode with a Netgear Orbi RBR750. The device I'm testing on is hardwired into the Orbit, and has a 1 Gigabit network card.
I set up a BQM once it was installed an I've noticed that whenever I start uploading, the graph shows latency increasing, and sometimes a bit of packet loss.
So I decided to run some tests on the upload, and a continuous test of upload and download is showing that while download is perfectly fine, the upload side is losing around 1%-5% of packets sent.
Looking into the logs on the modem I'm getting a few T3 Timeouts and the modulation isn't correct on all of the channels.
Attached are some test images and stats/logs from the hub 4. Regarding how our Virgin Media is delivered, its via RFOG and I've checked all the coax from the router to the ONT is tight. The ONT plug light is always solid green so it doesn't look like its cutting out either.
antbates91
  • 6
Message 2 of 10
Re: Upload Speed / Packet loss
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
330750000
1.000000
38.605377
QAM256
25
1
138750000
3.000000
38.983261
QAM256
1
2
146750000
2.799999
40.366287
QAM256
2
3
154750000
2.799999
40.366287
QAM256
3
4
162750000
2.500000
38.983261
QAM256
4
5
170750000
2.400002
38.605377
QAM256
5
6
178750000
2.000000
38.605377
QAM256
6
7
186750000
2.000000
38.983261
QAM256
7
8
194750000
2.099998
38.983261
QAM256
8
9
202750000
2.099998
38.983261
QAM256
9
10
210750000
2.099998
38.983261
QAM256
10
11
218750000
2.099998
38.983261
QAM256
11
12
226750000
2.299999
38.983261
QAM256
12
13
234750000
2.200001
38.983261
QAM256
13
14
242750000
2.099998
40.366287
QAM256
14
15
250750000
2.000000
38.983261
QAM256
15
16
258750000
2.099998
38.983261
QAM256
16
17
266750000
1.700001
38.983261
QAM256
17
18
274750000
1.200001
38.605377
QAM256
18
19
282750000
1.400002
38.983261
QAM256
19
20
290750000
1.700001
38.983261
QAM256
20
21
298750000
2.000000
40.366287
QAM256
21
22
306750000
1.299999
38.983261
QAM256
22
23
314750000
0.799999
38.983261
QAM256
23
24
322750000
0.799999
38.983261
QAM256
24
26
338750000
1.000000
38.983261
QAM256
26
27
346750000
0.799999
38.605377
QAM256
27
28
354750000
0.799999
38.983261
QAM256
28
29
362750000
1.099998
38.605377
QAM256
29
30
370750000
1.099998
38.983261
QAM256
30
31
378750000
0.799999
38.983261
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
38.605377
0
0
1
Locked
38.983261
0
0
2
Locked
40.366287
0
0
3
Locked
40.366287
0
0
4
Locked
38.983261
0
0
5
Locked
38.605377
0
0
6
Locked
38.605377
0
0
7
Locked
38.983261
0
0
8
Locked
38.983261
0
0
9
Locked
38.983261
0
0
10
Locked
38.983261
0
0
11
Locked
38.983261
0
0
12
Locked
38.983261
0
0
13
Locked
38.983261
0
0
14
Locked
40.366287
0
0
15
Locked
38.983261
0
0
16
Locked
38.983261
0
0
17
Locked
38.983261
0
0
18
Locked
38.605377
0
0
19
Locked
38.983261
0
0
20
Locked
38.983261
0
0
21
Locked
40.366287
0
0
22
Locked
38.983261
0
0
23
Locked
38.983261
0
0
24
Locked
38.983261
0
0
26
Locked
38.983261
0
0
27
Locked
38.605377
0
0
28
Locked
38.983261
0
0
29
Locked
38.605377
0
0
30
Locked
38.983261
0
0
31
Locked
38.983261
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
94
4K
1840
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
33
Locked
41
0.4
1292075766
0
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
35.020599
5120 KSym/sec
16QAM
3
2
46200000
34.770599
5120 KSym/sec
64QAM
2
3
53700000
34.770599
5120 KSym/sec
32QAM
1
4
32600000
35.020599
5120 KSym/sec
64QAM
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
3
0
2
US_TYPE_STDMA
0
0
1
0
3
US_TYPE_STDMA
0
0
2
0
4
US_TYPE_STDMA
0
0
0
0
Wed Feb 16 11:13:56 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 16 11:16:52 20226SW Download INIT - Via Config file cmreg-vmdg640-bbt062-b.cm
Wed Feb 16 11:18:05 20226SW download Successful - Via Config file
Wed Feb 16 11:20:39 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:01:22 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 16 11:28:13 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 16 11:50:52 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 17 16:49:07 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 20 00:47:19 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 20 11:54:08 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 23 12:47:20 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 1 03:58:22 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Mar 2 12:47:21 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 6.79K
  • 590
  • 1.78K
Message 3 of 10
Your Upstream is struggling.  The channels should all be connecting at 64QAM.  You will need a VM technician to fix this.  Wait here a day or two for a VM Mod to pick this up.
You could, in the meantime, try a 60 second factory pinhole reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Paulina_Z
  • 5.07K
  • 189
  • 395
Message 4 of 10
Hi @antbates91,
Welcome to our Community Forums! Thank you for your first post and I'm very sorry to hear that you've been experiencing some ongoing speed issues with your Hub.
After running some checks, I can see your upstream power levels are currently out of spec and will need a technician to visit your property to have this looked into further to resolve. However, I can see that you mentioned that your Hub is currently in Modem mode and connected to a third party router. As we're unable to provide technical assistance for third party routers, I would advise you put your Virgin Media Hub in router mode and reset your Hub as @Adduxi suggested.
Once those steps are complete and your power levels are sill not looking great after 24 hours, please let us know and we'll be happy to send over a technician to investigate further.
Thank you.
Paulina_Z
antbates91
  • 6
Message 5 of 10
I've rest the hub.
The stats looked better when it came back up but channel 3 and 2 were still at 32 QAM instead of 64.
The upload speeds are now hitting 35Mbps, however they are very unstable and still drop as low as 15Mbps before bouncing back up again. See the purple line below.
antbates91
  • 6
Message 6 of 10
253307500001.00000038.983261QAM25625
11387500002.90000238.983261QAM2561
21467500002.70000138.983261QAM2562
31547500002.79999938.983261QAM2563
41627500002.59999838.983261QAM2564
51707500002.29999938.983261QAM2565
61787500001.90000238.983261QAM2566
71867500001.90000238.983261QAM2567
81947500002.00000038.983261QAM2568
92027500002.09999838.983261QAM2569
102107500002.09999838.983261QAM25610
112187500002.09999838.983261QAM25611
122267500002.29999938.983261QAM25612
132347500002.20000138.983261QAM25613
142427500002.00000040.946209QAM25614
152507500001.90000238.983261QAM25615
162587500002.00000038.983261QAM25616
172667500001.59999838.983261QAM25617
182747500001.09999838.983261QAM25618
192827500001.29999938.983261QAM25619
202907500001.79999938.983261QAM25620
212987500001.90000240.366287QAM25621
223067500001.20000138.983261QAM25622
233147500000.70000138.983261QAM25623
243227500000.70000138.983261QAM25624
263387500001.00000038.983261QAM25626
273467500000.90000238.983261QAM25627
283547500000.79999938.983261QAM25628
293627500001.09999838.605377QAM25629
303707500001.00000038.605377QAM25630
313787500000.70000138.605377QAM25631
25Locked38.98326100
1Locked38.98326100
2Locked38.98326100
3Locked38.98326100
4Locked38.98326100
5Locked38.98326100
6Locked38.98326100
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
10Locked38.98326100
11Locked38.98326100
12Locked38.98326100
13Locked38.98326100
14Locked40.94620900
15Locked38.98326100
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked40.36628700
22Locked38.98326100
23Locked38.98326100
24Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked38.60537700
30Locked38.60537700
31Locked38.60537700
antbates91
  • 6
Message 7 of 10
33944K1840QAM4096424
33Locked410.3873234110
13940000035.0205995120 KSym/sec32QAM3
24620000035.0205995120 KSym/sec32QAM2
35370000035.0205995120 KSym/sec64QAM1
43260000035.2705995120 KSym/sec32QAM4
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
As the above monitor shows, everything is fine until I start doing uploading.
antbates91
  • 6
Message 8 of 10
Chris_W1
  • 6.52K
  • 274
  • 438
Message 9 of 10
Hi antbates91, thanks for the message and posting on the forums. I have looked into this and cannot see any issues. I will send you a private message so that further tests can be run. Please look out for the purple envelope. ^Chris
nennolello
  • 20
Message 10 of 10
If you ever find the culprit let us know since I am suffering from the same issues and after changing hub, coax cable, having received visits from 3 different VM tech guys and have been told my line is good I am still experiencing what you just told: fluctuating and poor upload and random freeze requesting web pages.
-Thankls
