on 03-10-2022 20:26
Since Saturday (1st October 2022) I have had poor upload speeds, <8Mbps on a 1gig line, the download speed is fine. Looking into this it appears as though from almost bang on 1pm which seems suspiciously round, there has been signal loss on the line (see attached thinkbroadband) then looking further into the router stats the upload channels are syncing at 32QAM on all but one of the channels which doesn't appear to be right, I'm sure these were 64 previously.
Virgin CS doesn't appear to see any faults and believe they don't guarantee uploads despite this causing an issue with certain connections. Any ideas how to progress? Have tried all the basics checking cables and resetting Virgin Hub 4.
on 03-10-2022 22:40
Hi @amel2018
There are a lot of tech guru's on the forum that can look into your issues but when posting the hub stats they need the full details from the Router Status page. So please copy/paste 3 FULL sets of data onto here (not screenshots) – from the Downstream, Upstream, & Network Logs pages.
on 04-10-2022 07:01
Thanks for the advice, full output below:
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
26 | 339000000 | -10.099998 | 36.386890 | QAM256 | 26 |
1 | 139000000 | -8.099998 | 37.636276 | QAM256 | 1 |
2 | 147000000 | -8.200001 | 37.636276 | QAM256 | 2 |
3 | 155000000 | -8.200001 | 37.636276 | QAM256 | 3 |
4 | 163000000 | -8.299999 | 37.355988 | QAM256 | 4 |
5 | 171000000 | -8.400002 | 37.636276 | QAM256 | 5 |
6 | 179000000 | -8.299999 | 37.355988 | QAM256 | 6 |
7 | 187000000 | -8.200001 | 37.355988 | QAM256 | 7 |
8 | 195000000 | -8.200001 | 37.355988 | QAM256 | 8 |
9 | 203000000 | -8.299999 | 37.355988 | QAM256 | 9 |
10 | 211000000 | -8.599998 | 37.355988 | QAM256 | 10 |
11 | 219000000 | -8.500000 | 37.636276 | QAM256 | 11 |
12 | 227000000 | -8.599998 | 37.355988 | QAM256 | 12 |
13 | 235000000 | -8.700001 | 37.355988 | QAM256 | 13 |
14 | 243000000 | -9.000000 | 37.636276 | QAM256 | 14 |
15 | 251000000 | -9.099998 | 37.355988 | QAM256 | 15 |
16 | 259000000 | -9.299999 | 37.355988 | QAM256 | 16 |
17 | 267000000 | -9.400002 | 37.355988 | QAM256 | 17 |
18 | 275000000 | -9.299999 | 37.355988 | QAM256 | 18 |
19 | 283000000 | -9.200001 | 37.355988 | QAM256 | 19 |
20 | 291000000 | -9.200001 | 36.609653 | QAM256 | 20 |
21 | 299000000 | -9.299999 | 36.386890 | QAM256 | 21 |
22 | 307000000 | -9.700001 | 36.386890 | QAM256 | 22 |
23 | 315000000 | -9.900002 | 36.386890 | QAM256 | 23 |
24 | 323000000 | -10.000000 | 36.386890 | QAM256 | 24 |
25 | 331000000 | -10.099998 | 36.386890 | QAM256 | 25 |
27 | 347000000 | -10.099998 | 36.386890 | QAM256 | 27 |
28 | 355000000 | -9.900002 | 36.386890 | QAM256 | 28 |
29 | 363000000 | -9.900002 | 36.386890 | QAM256 | 29 |
30 | 371000000 | -9.799999 | 36.609653 | QAM256 | 30 |
31 | 379000000 | -10.000000 | 36.609653 | QAM256 | 31 |
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
26 | Locked | 36.386890 | 475 | 0 |
1 | Locked | 37.636276 | 1217 | 0 |
2 | Locked | 37.636276 | 43 | 0 |
3 | Locked | 37.636276 | 0 | 0 |
4 | Locked | 37.355988 | 0 | 0 |
5 | Locked | 37.636276 | 0 | 0 |
6 | Locked | 37.355988 | 1 | 0 |
7 | Locked | 37.355988 | 0 | 0 |
8 | Locked | 37.355988 | 0 | 0 |
9 | Locked | 37.355988 | 0 | 0 |
10 | Locked | 37.355988 | 0 | 0 |
11 | Locked | 37.636276 | 0 | 0 |
12 | Locked | 37.355988 | 0 | 0 |
13 | Locked | 37.355988 | 0 | 0 |
14 | Locked | 37.636276 | 0 | 0 |
15 | Locked | 37.355988 | 0 | 0 |
16 | Locked | 37.355988 | 0 | 0 |
17 | Locked | 37.355988 | 0 | 0 |
18 | Locked | 37.355988 | 0 | 0 |
19 | Locked | 37.355988 | 3 | 0 |
20 | Locked | 36.609653 | 23 | 0 |
21 | Locked | 36.386890 | 113 | 0 |
22 | Locked | 36.386890 | 230 | 0 |
23 | Locked | 36.386890 | 586 | 0 |
24 | Locked | 36.386890 | 656 | 0 |
25 | Locked | 36.386890 | 812 | 0 |
27 | Locked | 36.386890 | 236 | 0 |
28 | Locked | 36.386890 | 53 | 0 |
29 | Locked | 36.386890 | 28 | 0 |
30 | Locked | 36.609653 | 6 | 0 |
31 | Locked | 36.609653 | 1 | 0 |
Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
159 | Locked | 38 | -8.3 | 353277445 | 6 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 39400000 | 44.520599 | 5120 KSym/sec | 32QAM | 12 |
2 | 25800000 | 44.520599 | 5120 KSym/sec | 64QAM | 14 |
3 | 32600000 | 44.520599 | 5120 KSym/sec | 32QAM | 13 |
4 | 46200000 | 44.520599 | 5120 KSym/sec | 32QAM | 11 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 40 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
Network log on next reply
on 04-10-2022 07:01
Time | Priority | Description |
Wed Sep 7 03:17:54 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Sep 8 17:11:23 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 9 02:42:56 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 9 13:05:57 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 9 13:05:57 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Sep 10 02:48:11 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Sep 10 09:03:55 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep 12 04:42:06 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep 12 08:54:00 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 13 01:05:57 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 13 01:05:57 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 13 04:12:06 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 16 13:05:58 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 16 13:05:58 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 16 18:59:12 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 18 02:36:15 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 18 03:34:45 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 20 01:05:58 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 20 01:05:58 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 20 02:14:42 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 20 09:59:53 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep 21 02:25:27 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Sep 22 00:51:10 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 23 02:36:03 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 23 06:38:19 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 23 13:05:58 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 23 13:05:58 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 23 23:16:44 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Sep 24 05:31:33 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Sep 24 14:52:54 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 25 02:51:35 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep 26 11:15:19 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 27 01:05:58 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 27 01:05:58 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep 28 02:07:09 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 30 13:05:58 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 30 13:05:59 2022 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Sep 30 13:20:57 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Oct 1 03:22:52 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Oct 1 04:57:27 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 12:11:38 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 12:11:50 2022 | 5 | Auth Reject - No Information;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 12:12:13 2022 | 6 | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: 790148; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 12:22:02 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 17:24:39 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 2 17:24:48 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 06-10-2022 09:09
Hey amel2018, thank you for reaching out and a warm welcome to the community, I am sorry you are having some connection issues.
I would like to run some in-depth tests via a PM, please can you look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
