Upload Speed Fluctuations
Iowa22
Hey Folks. Recently upped my plan from M125 to m250 As my upload speed was just not up to standards required to stream. For the past couple of weeks i've been streaming with a solid upload speed to start with, then suddenly i get a massive drop off in upload speed for a few seconds and then returns to normal, and this repeats every couple of minutes.Some days it's okay, some days it's completely unusable.
Looking to see if there's any info you guys can see that could point me in the right direction for a solution? Did all the standard Router reset/reboot, switched ethernet cables etc. I've got a technician booked for tuesday but that's not for broadband support, it's a separate TV issue.
Here's my info:
DOWNSTREAM BONDED CHANNELS
1139000000-7.537256 qam1
2147000000-7.738256 qam2
3155000000-7.737256 qam3
4163000000-8.537256 qam4
5171000000-8.737256 qam5
6179000000-8.738256 qam6
7187000000-937256 qam7
8195000000-9.537256 qam8
9203000000-1136256 qam9
10211000000-1236256 qam10
11219000000-12.436256 qam11
12227000000-12.734256 qam12
13235000000-1435256 qam13
14243000000-14.735256 qam14
15251000000-1534256 qam15
16259000000-14.734256 qam16
17267000000-14.835256 qam17
18275000000-14.834256 qam18
19283000000-14.735256 qam19
20291000000-14.235256 qam20
21299000000-1434256 qam21
22307000000-14.534256 qam22
23315000000-14.934256 qam23
24323000000-14.534256 qam24
14960000051512064 qam1
24310000051512064 qam2
32360000049.5512016 qam5
43660000050.3512064 qam3
53010012650.5512064 qam4
1ATDMA0020
3ATDMA0020
4ATDMA0000
5ATDMA0000
7 REPLIES 7
Iowa22
20/05/2023 19:05:10noticeLAN login Success;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 18:46:25Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 18:01:41criticalNo Ranging Response received - T3 time-out;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 17:49:18Warning!RCS Partial Service;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 17:49:18criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 17:49:10Warning!RCS Partial Service;CM-CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 16:23:27Warning!RCS Partial Service;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 16:23:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 15:32:57criticalNo Ranging Response received - T3 time-out;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 15:27:10Warning!RCS Partial Service;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 15:27:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 15:25:35Warning!RCS Partial Service;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 13:03:32criticalNo Ranging Response received - T3 time-out;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 12:19:24Warning!RCS Partial Service;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 12:17:2criticalNo Ranging Response received - T3 time-out;CM-CM-QOS=1.1;CM-VER=3.0;
20/05/2023 11:35:5Warning!RCS Partial Service;CM-;CM-QOS=1.1;CM-VER=3.0;
20/05/2023 11:35:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-CMTS-VER=3.0;
20/05/2023 09:57:9Warning!RCS Partial Service;CM-VER=3.0;
20/05/2023 09:57:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-;CMTS-VER=3.0;
I Have removed the MAC Address from the network log just to make you aware if it looks funny!
I'm currently also using a broadband quality monitor however this only has a couple of hours of info currently
any help appreciated, thank you!
you need someone to fix your line
Hey! thanks for the reply 🙂
It's good to know it's not on my end. May i ask how you could tell there was a fault with the line? it would better help me resolve this!
Lower downstream power levels resulting in low SnR and upstream some what high with drop Modulation
Thanks, Alessandro. Just a final question if i may, is that the line from the box outside in the street into my house ?
Sure the cable may or may not be the problem but whats in the box like a amp
Thanks kindly for the info. Apparently the issue will resolved by the 30th May but I'm praying it's earlier, as that's a full 9 days going with spotty internet hah
