rewarriner
  • 14
Message 1 of 13
Upgrading to M350 made no difference to download speed
As part of what I assume was a targetted promotion I upgraded our broadband to M350. Before the upgrade we usually achieved between 80 and 180mbps but now we seldom acheive better than 90mbps. The Superhub 3 is regularly restarted - mainly due to it being so flaky! House is wired with ethernet and gigabit switches so it isn't a WiFi issue.
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 2 of 13
Re: Upgrading to M350 made no difference to download speed
How are you speedtesting?
With a wired or wireless connection?
rewarriner
  • 14
Message 3 of 13
It is a wired speedtest.
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 4 of 13
90Mbps on a wired connection usually means only a 10/100 network card or a CAT5 cable.
rewarriner
  • 14
Message 5 of 13
I appreciate your help, but I did mention in my initial post that it is wired and I am using Gigabit switches. It isn't being limited by cables or switches.
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 6 of 13
Post the network, upstream and downstream logs from the hub admin pages
Anonymous
Not applicable
Message 7 of 13
Just in case you are not sure how to, access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option.
rewarriner
  • 14
Message 8 of 13
There is a limit of 20k characters so I need to post over multiple replies.
1330750000-2.537256 qam25
22027500000.737256 qam9
32107500000.536256 qam10
4218750000-0.236256 qam11
52267500000.737256 qam12
62347500000.738256 qam13
7242750000-0.438256 qam14
8250750000040256 qam15
92587500000.440256 qam16
10266750000-0.438256 qam17
11274750000-1.538256 qam18
12282750000-237256 qam19
13290750000-138256 qam20
14298750000-1.240256 qam21
15306750000-238256 qam22
16314750000-2.938256 qam23
17322750000-1.938256 qam24
18370750000-338256 qam26
19378750000-3.238256 qam27
20386750000-2.238256 qam28
21394750000-1.538256 qam29
22402750000-1.538256 qam30
23410750000-1.538256 qam31
24418750000-1.938256 qam32
1Locked37.3270
2Locked37.3270
3Locked36.6360
4Locked36.3230
5Locked37.390
6Locked38.9130
7Locked38.9300
8Locked40.3370
9Locked40.3150
10Locked38.990
11Locked38.9210
12Locked37.6320
13Locked38.9480
14Locked40.3250
15Locked38.9300
16Locked38.6250
17Locked38.6230
18Locked38.9140
19Locked38.9190
20Locked38.9110
21Locked38.950
22Locked38.660
23Locked38.660
24Locked38.990
1326000294.575512064 qam11
2537000264.25512064 qam13
3258000144.2512064 qam12
4394000094.575512064 qam10
3ATDMA0000
4ATDMA0000
rewarriner
  • 14
Message 9 of 13
Part 2,
3ATDMA0000
4ATDMA0000
14/07/2020 14:43:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:41:41criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:40:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:40:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:40:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:40:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:33:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:32:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:32:19criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:32:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:32:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:32:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:30:4criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:29:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:29:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:29:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:20:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 14:20:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
rewarriner
  • 14
Message 10 of 13
Sorry for the multiple posts but the forum limits the size of the posting.
Many thanks for any suggestions.
