Noam
  • 11
Message 1 of 13
Upgraded to M500 from M200, speed went down o.O
Been on M200 and always had constant 220Mbps in speedtest.  Router in modem mode into Asus RT-AC1200G+ and cable connection to main PC.
Got upgraded to M500 and have seen my upload speed jump up to a constant 37 Mbps which I am delighted with.  However, the download seems to have dropped to 150/160Mbps fairly constant
https://i.imgur.com/amJlodk.png
Can anyone help me with this?  I used to max the 220 Mbps on even my 5G wifi devices.
Have set up the ThinkBroadband thing
https://www.thinkbroadband.com/broadband/monitoring/quality/share/dc41212973fc04c4f107c30eac0becb481...
Info from Virgin modem
Item Status Comments
299000000
Locked
Ranged Upstream Channel (Hz)
25800072
Locked
Provisioning State
Online
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12990000003.737256 qam21
21390000006.537256 qam1
3147000000637256 qam2
41550000005.537256 qam3
51630000005.337256 qam4
61710000005.137256 qam5
7179000000537256 qam6
81870000004.937256 qam7
91950000004.537256 qam8
102030000004.337256 qam9
11211000000437256 qam10
122190000003.937256 qam11
132270000003.537256 qam12
142350000003.437256 qam13
152430000003.237256 qam14
162510000003.237256 qam15
172590000003.237256 qam16
182670000003.237256 qam17
192750000003.437256 qam18
202830000003.737256 qam19
212910000003.737256 qam20
223070000003.738256 qam22
23315000000437256 qam23
24323000000437256 qam24
1Locked37.6294228734
2Locked37.326585804
3Locked37.325487768
4Locked37.325497739
5Locked37.325195266
6Locked37.624077937
7Locked37.625047754
8Locked37.625167859
9Locked37.324867370
10Locked37.626377090
11Locked37.325997229
12Locked37.625237310
13Locked37.327597398
14Locked37.327177234
15Locked37.626882495
16Locked37.629737040
17Locked37.627156622
18Locked37.326816834
19Locked37.626824015
20Locked37.627333541
21Locked37.627143167
22Locked38.6286816349
23Locked37.6288816397
24Locked37.6303829575
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1258000724.8512064 qam11
2461998884.775512064 qam3
3393999824.8512064 qam4
4326000304.825512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Anyone help?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 13
Re: Upgraded to M500 from M200, speed went down o.O
Your BQM even in its infancy is showing dropped packets.
Your Hub stats look OK.
I take it your speed test has been done through your Asus RT-AC1200G+  ?
Can you do a couple using a direct connection with a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other items connected ?
Noam
  • 11
Message 3 of 13
Bizarrely, when I take the cable from the virgin router and plug it direct into the PC (intel I211 gigabit card), it shows no internet.  Have tried this with both my PC and my work laptop
Yet I plug the same cable into the asus router and pc into the asus router it all works fine.
Do you think I should take the virgin out of modem mode back to router mode and set back?  Very confusing
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 13
In Modem Mode you only have one active ethernet port on the Hub.
Noam
  • 11
Message 5 of 13
Sorry, I think I've confused myself
I run it in modem mode, that one port from the virgin box I put into the ASUS and do everything from the ASUS (albeit with recent speed issues since I went up to M500)
As per your suggestion, I took the cable from the virgin box in modem modem out of the ASUS and straight into a PC and my laptop, but they can't get an IP when I do this (bizarrely).  Put that cable back into the ASUS and ASUS to PC/laptop both fine
I'm going to take the virgin box back to router mode and retest
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 13
OK.
Until the speed at the Hub is known we can't really do any troubleshooting.
I will expect the change from Modem to Router Mode to show as a full height red band on the BQM.
Noam
  • 11
Message 7 of 13
Well, I think I need to look at how my ASUS router is behaving
https://i.imgur.com/tI1fv5S.png
Blistering speed with the virgin box in router mode
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 13
Leave the connections as they are and go back to Modem Mode, and reboot the PC into Safe Mode with Networking and run speed tests again.
Noam
  • 11
Message 9 of 13
so put it straight back into modem mode, and full speed
https://i.imgur.com/yhu6sL5.png
So modem mode - slow, back to router mode fast, back to router mode fast
Will now connect the asus back up and see how it reacts
Noam
  • 11
Message 10 of 13
Well, I guess its time to reset the ASUS back to factory settings
https://i.imgur.com/2L8zYBd.png
