Ravenger
  • 22
Message 1 of 9
Upgraded to M350 a while ago, but it's not much faster than when I had M200.
Hi, I upgraded to M350 from M200 a few months ago, but I'm not seeing much faster internet than when I was on M200. It is a bit faster, but not by much - not enough to justify the upgrade. I used to get about 206mbit/s, now I'm getting 227mbit/s.
I've given it a bit of time to see if things have improved, but it's stayed the same.
I'm disappointed as the upgrade seems to be a bit of a waste of money if I'm not seeing any improvement, I might as well have stayed at M200.
My modem is in modem mode, and I have a D-Link DIR-878 router. That's got a 1000Mbit/s LAN connection, so that shouldn't be the limiting factor. Windows shows the connection as being 1000Mbit/s.
Any help gratefully recieved, thanks!
jem101
  • 4.25K
  • 436
  • 1.81K
Community elder
Message 2 of 9
Re: Upgraded to M350 a while ago, but it's not much faster than when I had M200.
The first thing I would try is to go through all of the connections on the DLINK and look for any QoS settings (and personally I hate that terms as it’s nothing. To do with what QoS technically is - rant over), which might be limiting the bandwidth.
  • 6.09K
  • 512
  • 1.57K
Message 3 of 9
@Ravenger wrote:
<snip>    My modem is in modem mode, and I have a D-Link DIR-878 router. That's got a 1000Mbit/s LAN connection, so that shouldn't be the limiting factor.
Just for information, and off topic of this thread, it’s a wrong assumption that a gigabit LAN connection equates to a gigabit WAN throughput. My old Draytek 2860 has a gigabit WAN port, but only has a 300mb WAN throughput. It’s something users often overlook when choosing a Router.
jpeg1
  • 6.9K
  • 355
  • 1.28K
Legend
Message 4 of 9
Is it really off topic?   Has @Ravenger tried a direct connection without the additional router?
Ravenger
  • 22
Message 5 of 9
Not yet. I guess I'll have to reset the modem back into router mode to do that.
jpeg1
  • 6.9K
  • 355
  • 1.28K
Legend
Message 6 of 9
No. It will work in modem mode.
Steven_L
  • 10.23K
  • 622
  • 1.06K
Message 7 of 9
Hey @Ravenger,
Thanks for taking the time to post here on our forums.
I'm really sorry to hear of the issues that you're having with your connection.
Have you been able to get any improvements of your services with the advice from the forum members?
I have also looked into your account and cannot see anything that would be causing the issues with your connection as everything is well within the spec for a good connection.
Regards,
Steven_L
Ravenger
  • 22
Message 8 of 9
Thanks for checking. I haven't yet tried direct connection to my superhub. I'll give it a try this weekend.
Cheers.
Martin_N
  • 8.34K
  • 351
  • 510
Message 9 of 9
Thank you for that. Please do let us know how it goes.
^Martin
