BUenas
  • 7
Message 1 of 14
Upgraded to Gig1 Fibre - seeing heavy speed fluctuation.
Gooday all,
I've recently upgraded to the Gig1 Fibre, however I'm having speed inconsistencies.
With a direct ethernet connection I've reached a maximum of 751.62 Mbps, but otherwise that only lasted for a brief moment. Speeds are varying wildy as seen in the image below (the last entries, 8:17 & 8:16, show changes within one minute)
With the second image, you can see that the M350 was more or less always within the same speed range.
It seems I can only expect to get consistant speeds at around the 400Mbps mark.
I would also provide the downstreams and what not, however Hub 4 does not seem to allow me to view those on the Router Status page.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Upgraded to Gig1 Fibre - seeing heavy speed fluctuation.
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
BUenas
  • 7
Message 3 of 14
I'm using Cat6a. Both the ethernet cable and the coaxial cable have been repurchased, however no changes.
Sam Knows is showing 574Mbps to Hub 4 and 656Mbps to computer, with no other devices connected.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 14
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 14
BUenas
  • 7
Message 6 of 14
I will return with the BQM results later after it gathers up a bit of info.
DOWNSTREAM
30402750000-3.50000038.605377QAM25630
11387500001.20000131.136440QAM2561
21467500001.40000231.335388QAM2562
31547500001.29999933.956509QAM2563
41627500002.20000135.595078QAM2564
51707500000.70000135.595078QAM2565
61787500000.90000236.386890QAM2566
71867500001.09999837.355988QAM2567
81947500000.59999836.609653QAM2568
92027500000.40000234.345688QAM2569
102107500000.00000033.062504QAM25610
112187500000.20000128.126141QAM25611
12226750000-0.90000229.529472QAM25612
13234750000-1.09999837.355988QAM25613
14242750000-0.79999936.174995QAM25614
152507500000.90000237.636276QAM25615
162587500000.59999838.983261QAM25616
172667500002.59999838.983261QAM25617
182747500000.70000138.983261QAM25618
192827500002.00000038.983261QAM25619
202907500000.70000138.605377QAM25620
212987500001.20000138.983261QAM25621
223067500001.20000138.983261QAM25622
233147500000.09999838.983261QAM25623
243227500001.70000138.983261QAM25624
25330750000-0.79999938.605377QAM25625
26370750000-3.70000138.983261QAM25626
27378750000-2.50000038.605377QAM25627
28386750000-4.70000138.605377QAM25628
29394750000-2.90000236.386890QAM25629
31410750000-2.59999838.605377QAM25631
30Locked000
1Locked8001416088130255404
2Locked809629238464846138
3Locked8062554531289390
4Locked9279814801610
5Locked810070089840580
6Locked80998801040951029
7Locked797878195254370
8Locked3231846814041422
9Locked3239546143277872
10Locked235477218167938544
11Locked306534273563335234385
12Locked3218497606077433034
13Locked32535793410
14Locked3247629247220
15Locked32029416800
16Locked35421174400
17Locked33669248900
18Locked33766274000
19Locked33771834200
20Locked28786794300
21Locked33291507700
22Locked33980156000
23Locked34112512800
24Locked44018671200
25Locked45737133500
26Locked47455697000
27Locked48161779500
28Locked124456920900
29Locked47088636200
31Locked92942556300
33864K1680QAM4096424
33Locked -2.968997886386
BUenas
  • 7
Message 7 of 14
UPSTREAM
13940000048.7705995120 KSym/sec64QAM2
24620000051.7705995120 KSym/sec64QAM1
32580000047.5205995120 KSym/sec64QAM4
43260000048.5205995120 KSym/sec64QAM3
1US_TYPE_STDMA0020
2US_TYPE_STDMA0020
3US_TYPE_STDMA0020
4US_TYPE_STDMA0020
BUenas
  • 7
Message 8 of 14
CONFIGURATION
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
1241068
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
1241067
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
NETWORK LOG
Empty.
Anonymous
Not applicable
Message 9 of 14
DOWNSTREAM
30Locked000
13Locked32535793410
15Locked32029416800
16Locked35421174400
17Locked33669248900
18Locked33766274000
19Locked33771834200
20Locked28786794300
21Locked33291507700
22Locked33980156000
23Locked34112512800
24Locked44018671200
25Locked45737133500
26Locked47455697000
27Locked48161779500
29Locked47088636200
31Locked92942556300
You have a SNR issue on a number of your downstream channels.
A large number of errors caused by the above.
Your Docsis 3.1 channel is low on power
BUenas
  • 7
Message 10 of 14
BQM results as requested - all seems to be fine so far.
My BQM
