BubbleTree
  • 5
Message 1 of 7
Upgraded to Gig1 Fibre - Latency Spikes/fluctuation in speed
Hi there!
I've just upgraded from the 350mb internet package to the Gig1 Fibre and I've noticed I'm getting quite a lot of latency spikes/couple of random router restarts (which then resets the password on the router, and both the default (one printed on the bottom) and my set password won't work).
I've been reading a couple of posts and a few people have mentioned that in the network stats, you want a downstream power closest to 0 dBmV, but nothing over 10. All of mine are at about 11 - 12 dBmV (I can't screenshot/post right now as for some reason the status page has stopped loading!!!) On the cable coming in from the wall, there is already a 10db attenuator from when I first joined Virgin Media a few years ago (so I think when I had the original SuperHub 2 installed by the engineer, and then also when I had the Superhub 3). Could the "high" 12 dBmV on my downstream be an issue?
Here is a link to my TBB monitor (Live)
0fe7c8f9f2b916ee3b701ff89b0435cf5c219d9a
And a snapshot
4aab5ff86393bb6423a63700162a824d1aa3c180-14-11-2020
If anyone can offer any help, or point me in the right direction I'd really appreciate it!! 🙂  I'm using a Cat7 Ethernet cable (saw in some other threads people checking if they had a cat6+) so the connection between my PC and router should be fine!. 🙂
BubbleTree
  • 5
Message 2 of 7
Re: Upgraded to Gig1 Fibre - Latency Spikes/fluctuation in speed
3.0 Downstream channels
113900000011.00000038.983261QAM2561
214700000010.80000338.983261QAM2562
315500000010.90000240.366287QAM2563
416300000010.80000340.946209QAM2564
517100000010.69999740.366287QAM2565
617900000010.69999740.366287QAM2566
718700000010.80000340.946209QAM2567
819500000011.00000040.366287QAM2568
920300000011.19999738.983261QAM2569
1021100000011.30000338.983261QAM25610
1121900000011.30000340.366287QAM25611
1222700000011.30000338.983261QAM25612
1323500000011.30000338.605377QAM25613
1424300000011.50000038.605377QAM25614
1525100000011.69999738.983261QAM25615
1625900000012.09999838.983261QAM25616
1726700000011.90000240.366287QAM25617
1827500000011.40000240.366287QAM25618
1928300000011.09999840.366287QAM25619
2029100000010.90000240.366287QAM25620
2129900000011.09999838.983261QAM25621
2230700000011.50000038.983261QAM25622
2331500000011.69999738.983261QAM25623
2432300000011.69999738.983261QAM25624
2536300000011.50000038.983261QAM25625
2637100000011.50000039.397190QAM25626
2737900000011.59999840.366287QAM25627
2838700000011.80000338.605377QAM25628
2939500000012.09999838.983261QAM25629
3040300000012.40000240.946209QAM25630
3141100000012.59999840.366287QAM25631
1Locked000
2Locked293600
3Locked387800400
4Locked293600
5Locked293600
6Locked293600
7Locked293600
8Locked293600
9Locked293600
10Locked293600
11Locked293670
12Locked293600
13Locked293600
14Locked293600
15Locked293600
16Locked293600
17Locked293600
18Locked293600
19Locked293600
20Locked293600
21Locked293600
22Locked293600
23Locked293680
24Locked293600
25Locked293600
26Locked293600
27Locked293600
28Locked293610
29Locked293600
30Locked293600
31Locked1749707700
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
159964K1880QAM4096759
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
159Locked 13.026640
BubbleTree
  • 5
Message 3 of 7
Here is my router stats for the downstream, for some reason my post keeps getting deleted about 5 minutes after I post this 😞
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
11.000000
38.983261
QAM256
1
2
147000000
10.800003
38.983261
QAM256
2
3
155000000
11.000000
40.366287
QAM256
3
4
163000000
10.900002
40.366287
QAM256
4
5
171000000
10.699997
40.366287
QAM256
5
6
179000000
10.699997
40.366287
QAM256
6
7
187000000
10.800003
40.366287
QAM256
7
8
195000000
11.000000
40.366287
QAM256
8
9
203000000
11.199997
38.605377
QAM256
9
10
211000000
11.400002
38.983261
QAM256
10
11
219000000
11.300003
40.366287
QAM256
11
12
227000000
11.400002
38.983261
QAM256
12
13
235000000
11.400002
38.605377
QAM256
13
14
243000000
11.599998
38.983261
QAM256
14
15
251000000
11.800003
38.983261
QAM256
15
16
259000000
12.199997
38.983261
QAM256
16
17
267000000
12.000000
40.366287
QAM256
17
18
275000000
11.400002
40.366287
QAM256
18
19
283000000
11.099998
40.366287
QAM256
19
20
291000000
10.900002
40.366287
QAM256
20
21
299000000
11.000000
38.983261
QAM256
21
22
307000000
11.599998
38.983261
QAM256
22
23
315000000
11.800003
38.983261
QAM256
23
24
323000000
11.699997
38.983261
QAM256
24
25
363000000
11.400002
38.983261
QAM256
25
26
371000000
11.500000
38.983261
QAM256
26
27
379000000
11.699997
40.366287
QAM256
27
28
387000000
11.800003
38.983261
QAM256
28
29
395000000
12.099998
38.983261
QAM256
29
30
403000000
12.400002
40.366287
QAM256
30
31
411000000
12.500000
40.366287
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
0
0
0
2
Locked
110395556
0
0
3
Locked
180471833
0
0
4
Locked
110169629
0
0
5
Locked
110140006
0
0
6
Locked
110215786
0
0
7
Locked
110267231
0
0
8
Locked
99542121
0
0
9
Locked
99678741
0
0
10
Locked
99792056
0
0
11
Locked
99712472
0
0
12
Locked
99390647
0
0
13
Locked
99271639
1
0
14
Locked
99415779
0
0
15
Locked
99241982
1
0
16
Locked
100291393
0
0
17
Locked
100218947
0
0
18
Locked
100040154
0
0
19
Locked
100289338
0
0
20
Locked
100201126
0
0
21
Locked
100473728
0
0
22
Locked
100127946
1
0
23
Locked
100159002
1
0
24
Locked
108731270
1
0
25
Locked
109048389
1
0
26
Locked
108980178
0
0
27
Locked
108986882
1
0
28
Locked
108906016
0
0
29
Locked
108832044
1
0
30
Locked
108993529
1
0
31
Locked
392667155
0
0
Channel
Channel Width (MHz)
FFT Type
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
13.1
2375476
0
BubbleTree
  • 5
Message 4 of 7
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
11.000000
38.983261
QAM256
1
2
147000000
10.800003
38.983261
QAM256
2
3
155000000
10.900002
40.366287
QAM256
3
4
163000000
10.800003
40.946209
QAM256
4
5
171000000
10.699997
40.366287
QAM256
5
6
179000000
10.699997
40.366287
QAM256
6
7
187000000
10.800003
40.946209
QAM256
7
8
195000000
11.000000
40.366287
QAM256
8
9
203000000
11.199997
38.983261
QAM256
9
10
211000000
11.300003
38.983261
QAM256
10
11
219000000
11.300003
40.366287
QAM256
11
12
227000000
11.300003
38.983261
QAM256
12
13
235000000
11.300003
38.605377
QAM256
13
14
243000000
11.500000
38.605377
QAM256
14
15
251000000
11.699997
38.983261
QAM256
15
16
259000000
12.099998
38.983261
QAM256
16
17
267000000
11.900002
40.366287
QAM256
17
18
275000000
11.400002
40.366287
QAM256
18
19
283000000
11.099998
40.366287
QAM256
19
20
291000000
10.900002
40.366287
QAM256
20
21
299000000
11.099998
38.983261
QAM256
21
22
307000000
11.500000
38.983261
QAM256
22
23
315000000
11.699997
38.983261
QAM256
23
24
323000000
11.699997
38.983261
QAM256
24
25
363000000
11.500000
38.983261
QAM256
25
26
371000000
11.500000
39.397190
QAM256
26
27
379000000
11.599998
40.366287
QAM256
27
28
387000000
11.800003
38.605377
QAM256
28
29
395000000
12.099998
38.983261
QAM256
29
30
403000000
12.400002
40.946209
QAM256
30
31
411000000
12.599998
40.366287
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
0
0
0
2
Locked
2936
0
0
3
Locked
3878004
0
0
4
Locked
2936
0
0
5
Locked
2936
0
0
6
Locked
2936
0
0
7
Locked
2936
0
0
8
Locked
2936
0
0
9
Locked
2936
0
0
10
Locked
2936
0
0
11
Locked
2936
7
0
12
Locked
2936
0
0
13
Locked
2936
0
0
14
Locked
2936
0
0
15
Locked
2936
0
0
16
Locked
2936
0
0
17
Locked
2936
0
0
18
Locked
2936
0
0
19
Locked
2936
0
0
20
Locked
2936
0
0
21
Locked
2936
0
0
22
Locked
2936
0
0
23
Locked
2936
8
0
24
Locked
2936
0
0
25
Locked
2936
0
0
26
Locked
2936
0
0
27
Locked
2936
0
0
28
Locked
2936
1
0
29
Locked
2936
0
0
30
Locked
2936
0
0
31
Locked
17497077
0
0
Channel
Channel Width (MHz)
FFT Type
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
13.0
2664
0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 7
Your Upstream Power Levels are too high (Max 10dBmV)
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
BubbleTree
  • 5
Message 6 of 7
Hi Mike,
Thanks so much for getting back to me! Do you mean my Downstream Power Levels? For somereason whenever I posted by my Downstream and Upstream stuff it would delete the 2nd post 😞
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
31.020599
5120 KSym/sec
64QAM
4
2
32600000
30.020599
5120 KSym/sec
64QAM
5
3
46200000
31.520599
5120 KSym/sec
64QAM
3
4
53700000
32.020599
5120 KSym/sec
64QAM
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
1
0
2
US_TYPE_STDMA
0
0
1
0
3
US_TYPE_STDMA
0
0
1
0
4
US_TYPE_STDMA
0
0
1
0
I was worried I might need an engineer, thanks for flagging that, might give them a call (guessing it will have to be Monday now!), is it the same number as customer services? 0345 454 1111?
Cheers!
My Broadband Ping - Virgin Fibre
Alex_RM
  • 4.48K
  • 258
  • 341
Message 7 of 7
Hi BubbleTree,
Thanks for posting and sorry to see you've been having some issues with your connection.
I've been able to locate your account using your forum details and can see you were able to get through to speak to an agent.
I have however run a check on your equipment and can see the hubs upstream and downstream power levels are out of specification. I've arranged for an engineer to come and take a closer look, you can view the time and date of your appointment via your online account here
Alex_Rm
