FeelyngGood
Upgraded to 1Gig today, SamKnows Down Speed to Hub4 318mbps?
Hi There,
I've just got the upgrade through today and I've been making sure everything is working as expected. I've noticed that my speed seems to be maxing out at 180 mbps wired so I was reading through various things and found the SamKnows speed test and it showed this:
Do I need to get someone to take a look at this or will this speed come up on its own the next few days?
RedGooner
  • 1.93K
  • 69
  • 259
Super solver
Re: Upgraded to 1Gig today, SamKnows Down Speed to Hub4 318mbps?
I also got 1Gig yesterday. My SH4 is in Modem Mode. This is my speed via Wired connection.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
@FeelyngGood wrote:
Speed increase should be within minutes.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
FeelyngGood
Okay so bit of an update. I did some tests and ended up restarting the hub a few times. Also discovered a Cat5 cable in my chain that I thought was Cat5e.
Having replaced that with a 5e I now am getting the expected speeds to the hub. ~930mbps.
However speed to the computer was still around 300mbps which I would like to get increased now.
What factors should I be looking at to increase that speed or is it likely a result of my network setup:
Hub4 modem mode -> Netduma R1 router -> 5 port switch -> computer
thanks for taking the time to assist!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Try testing without the Netduma R1 router & 5 port switch in the LAN.
