  • 7
Message 1 of 10
Upgraded speed
I upgraded from the 100Mb package to the 350Mb in January of this year.
After numerous calls with the "technical department" basically telling me to reset my router, I have still yet to ever receive more than 100Mb/s, cable or wifi.
Can anybody please help resolve the issue, as i am now 4 months into this deal and pretty much done with VM.
I am running the hub 3.
thank you in advance.
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 10
Re: Upgraded speed
What is the downstream traffic rate on the admin pages, under the configuration tab?
  • 7
Message 3 of 10
Re: Upgraded speed
Hi there,
Thanks for the reply, the downstream is as below.
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 10
Re: Upgraded speed
That’s the 350Mbps speed.
How are you Speedtesting?
  • 7
Message 5 of 10
Re: Upgraded speed
It is generally as it always has been on the 100mb/s package.
That being around 75-90 mb/s download with a 30-40 mb/s upload speed.
One taken just now, which is a little low, but given that VM seem to be having some issues at the minute.
https://www.speedtest.net/my-result/d/b6e6ded2-a699-436c-b056-01c5452b5207
  • 20.96K
  • 1.13K
  • 2.7K
Message 6 of 10
Re: Upgraded speed
What are you testing with?
What device, wired or wireless?
If wired are you using a CAT5e/CAT6/CAT7 cable connected to a gigabit Ethernet port?
  • 7
Message 7 of 10
Re: Upgraded speed
wired connection to a PC, Cat 5e cable and....100mb/s ethernet port.
Thank you for resolving my issue kind sir.
Any recommendations on upgrading to gb EP?
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 10
Re: Upgraded speed
Ah ha!
You could get a usb-gigabit Ethernet adaptor from Amazon.
Aside from the other obvious solution of getting a new pc/laptop 🙂
  • 7
Message 9 of 10
Re: Upgraded speed
Ha ha,
I think i have a better chance of winning the adapter argument than getting a new rig!!
again, thank you and stay safe!
  • 20.96K
  • 1.13K
  • 2.7K
Message 10 of 10
Re: Upgraded speed
Take your pick - the AmazonBasics or Anker model will be fine..
https://www.amazon.co.uk/s?k=usb+ethernet&ref=nb_sb_noss
