If the confirguration file is showing same as mine, it should be high as 220 down and 21 up on Okla speed test off peak times. Peak times is a different story unforetunately..lucky to get 10 up.
I can't comment how the games console uses the conection. Best way to check speed upgrade is connect a laptop with a decent quality cable direct to the hub3.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
