Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 1 of 13
Upgraded speed but not happened
On Monday I decided I would upgrade the speed to the M350 package but after 24 hours it didn’t happen so I went on the live chat instead of waiting for an hour on the phone. The agent talked me into a good deal to get the M500 speed for just an extra £12 per month on a new 18 month contract.
The agent said it would increase yesterday Tuesday on the same day I had originally wanted the M350 package. Well it hasn’t happened and I’m still stuck on the 200mb I was on when I joined, I’ve rebooted the hub but it hasn’t pushed the new upgrade through.
Can this get sorted?
——————————————— My Broadband Ping - Virgin 500mb Home Connection
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 13
Re: Upgraded speed but not happened
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 3 of 13
13310000002.540256 qam25
2203000000240256 qam9
3211000000240256 qam10
42190000001.940256 qam11
52270000001.740256 qam12
62350000001.540256 qam13
72430000001.440256 qam14
82510000001.240256 qam15
9259000000140256 qam16
10267000000140256 qam17
11275000000140256 qam18
122830000001.440256 qam19
132910000001.740256 qam20
14299000000240256 qam21
153070000002.240256 qam22
163150000002.240256 qam23
173230000002.440256 qam24
183390000002.540256 qam26
193470000002.540256 qam27
203550000002.540256 qam28
213630000002.740256 qam29
223710000002.940256 qam30
23379000000340256 qam31
24387000000340256 qam32
1Locked40.950
2Locked40.980
3Locked40.340
4Locked40.360
5Locked40.370
6Locked40.340
7Locked40.950
8Locked40.340
9Locked40.380
10Locked40.390
11Locked40.970
12Locked40.980
13Locked40.350
14Locked40.360
15Locked40.980
16Locked40.960
17Locked40.970
18Locked40.940
19Locked40.360
20Locked40.370
21Locked40.960
22Locked40.9100
23Locked40.360
24Locked40.900
Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 4 of 13
13260001241.8512064 qam13
23940004642.3512064 qam12
34620003642.3512064 qam11
45370004142.8512064 qam10
3ATDMA0000
4ATDMA0000
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ewrkldJKDHSUBsgvca69834ncxv98
SFID672
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID671
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 5 of 13
30/12/2020 03:14:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 05:43:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 05:43:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 05:43:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 14:40:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 14:09:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 12:30:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 10:13:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 10:13:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 15:39:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/12/2020 22:13:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/12/2020 22:13:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 05:05:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 10:13:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 10:13:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 15:35:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 22:13:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 22:13:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 16:57:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 15:04:39noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 13
You are still on the 200Mbs service.
SFID672
Min Traffic Rate0
SFID671
Min Traffic Rate0
Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 7 of 13
Is it normal to get no more than around 250mb on a WiFi connection on the M500? That’s what virgin told me.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 13
Please post the contents of the Hub Configuration tab.
Wi-Fi signal can be anything from 500 to zero depending on the environment and interference.
Nigel1971
  • 124
  • 6
  • 5
Up to speed
Message 9 of 13
I’m definitely not hitting the 500mb or more on a wired connection, it’s going 50mb less about 450-460.
General Configuration
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
d;kfoA,.iyewrkldJKDHSUBsgvca6
SFID672
Max Traffic Rate575000000
Min Traffic Rate0
SFID671
Max Traffic Rate
38520000
Min Traffic Rate0
Max Concatenated Burst16320
I’m certainly on the M500 now.
Eeeps
  • 899
  • 57
  • 157
Well-informed
Message 10 of 13
Is this any time of day or just now?
What speed test are you using?
Given your TBQM I would expect a little better.
Try a speed test early morning (6am) or better still at hourly intervals throughout the day.
My daytime rates are usually between 250-450 but dropped to 50 during the recent Amazon football streaming a couple of days ago.
