Skhm28
Message 1 of 5
Upgraded m200 to m350 now speed is lower
I had my broadband increased from 200mb to 350mb this week.
its been running close to 209/219mb for a year.  Now since the upgrade its running sub 200, closer to 50mb.  Do i need to reset my router for the change to take effect? Or Does the new speed take a while to sync?
i,m not happy having increased my monthly cost And reduced my speed.
comments?
Vmtech1
  • 67
  • 11
  • 16
Message 2 of 5
Re: Upgraded m200 to m350 now speed is lower
Yes please reset router hold a pin for 30-60 seconds once back up and running please check speed again.
Any issues please pm me
Hope this helps
Skhm28
Message 3 of 5
I rest for 40 seconds,  and speed is still running 208/18.
i will power reset and test again.
Any way to confirm the upgrade has actually been done?  I received a new invoice!
gary_dexter
  • 30.26K
  • 1.88K
  • 4.02K
Message 4 of 5
How are you Speedtesting? Wired or wireless?
Post back the Config details form here:
http://192.168.0.1/#configuration
Skhm28
Message 5 of 5
Hi Gary
thanks for responding.  I figured it out using both wired and wireless.  I have ORBI wifi around the house getting better results than a wired connection.
All behind FW, i forgot To change the throughput speed on the FW. Now im getting 320/33. Happy with that.
Case closed.
