jwt95
Upgraded from M250 to M500 but speed has not increased
I upgraded from 250mbps to 500mbps on Tue 31/01/2023 but still getting the same speeds today (Tue 02/02/2023).
https://samknows.com/realspeed/ gives "Router" speed of 274mbps.
I've checked the downstream "Max Traffic Rate" which is 287500061 (287mb). I've performed a pinhole reset and this has not fixed it.
Hub 3.0 device information
The information below shows current status of this Hub 3.0.
Standard specification compliant: DOCSIS 3.0
Hardware version: 11
Software version: 9.1.2109.200
Network Log (MAC removed)
02/02/2023 21:46:16noticeLAN login Success;CM-VER=3.0;
01/01/1970 00:01:42criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
02/02/2023 21:07:46notice
VER=3.0;
02/02/2023 21:06:57Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-
VER=3.0;
02/02/2023 20:59:52noticeSW download Successful - Via Config file
02/02/2023 20:57:7noticeSW Download INIT - Via Config file
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
02/02/2023 19:19:42notice
VER=3.0;
01/02/2023 10:56:45Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-
VER=3.0;
29/01/2023 08:10:30critical
VER=3.0;
29/01/2023 05:35:50notice
VER=3.0;
29/01/2023 05:31:14Warning!
VER=3.0;
28/01/2023 22:56:45Error
VER=3.0;
28/01/2023 22:30:29critical
VER=3.0;
25/01/2023 10:56:45Error
VER=3.0;
23/01/2023 08:22:17critical
VER=3.0;
22/01/2023 18:32:49Error
VER=3.0;
17/01/2023 19:55:2criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
17/01/2023 14:20:44Error
VER=3.0;
14/01/2023 15:06:35criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID10424
Max Traffic Rate287500061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID10423
Max Traffic Rate27500061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling Type
331000000
Locked
Ranged Upstream Channel (Hz)
49600000
Locked
Provisioning State
Online
Tags (1)
  • 20.48K
  • 828
  • 2.2K
Re: Upgraded from M250 to M500 but speed has not increased
You have not been upgraded yet but did you really need the speed?
jwt95
Probably not. Anyhow, sorted now. Needed to activate the VM Stream device which I never wanted.
Paul_DN
  • 10.7K
  • 546
  • 1.09K
Hi jwt95,
Thank you for reaching out to us in our community and welcome, sorry to hear you weren't seeing your speed increase however has now changed since you activated the stream box, this is due to it being part of a package, if you do need any further help, please do not hesitate to reach back out.
Paul.
