Mattcleeds
  • 10
Message 1 of 17
Upgraded from M100 to M200, speed unchanged
Yesterday (20 hours ago) I called to get an upgrade of my M100 to M200. After a few hours it showed at M200 in the Virgin media app, but my speeds remain at 95Mb down and 5Mb up.
Am I just being impatient and it will happen sometime soon? Or should I call back and get my service checked.
Its worth noting my normal speed was 108Mb down and 6Mb up when I have tested it previously.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 17
Re: Upgraded from M100 to M200, speed unchanged
Forget testing with Wi-Fi, it isn't accurate enough.
What speed do you get at >> speedtest.net << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mattcleeds
  • 10
Message 3 of 17
Thanks for the super quick response Mike!
I didn't add all the details to my original post. I'm using the hub in modem mode as I have a TP-Link Archer A7 setup with mesh wifi. Although having said that my PC is connected directly to the A7 via Cat 5E.
At some point, I will try resetting the home hub and connecting directly to that, but I've been told by the rest of my family if I take out internet offline today I'm in trouble! 🙂
I did retest via the PC and Ookla, just with the limitations mentioned above, and it gives a result of:
 PING ms 8
 DOWNLOAD Mbps 94.16
 UPLOAD Mbps 5.26
When I get time to do the reset and plug directly into the hub in router mode I'll post that result. I'm guessing from your reply that the upgrade should be minutes not hours though?
Thanks again,
Matt
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 17
Go into the Hub Settings and copy and paste the contents of the tables in the Configuration tab.
  • 23.86K
  • 2.53K
  • 4.33K
Message 5 of 17
94Mbps is always a suspicious number for those on higher speed packages. It often signifies that you are being limited to ~100 by your equipment.
Try a new ethernet cable first - they do fail and also that you NIC card is not limiting the PC by being set to 10/100 connections. Check its drivers are up to date.
Mattcleeds
  • 10
Message 6 of 17
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
fg87dsfd;kfoA,.iyewrkldJKDHSUB
SFID 436
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 435
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 17
Definitely configured for 200Mbs.
As John says the speed is indicative of an iffy ethernet cable or network card set at the wrong speed.
In the Hub Settings - Connected Devices, what is the indicated connection* speed ?
* This is the speed capability of the LAN connection not the actual speed of the connection.
Mattcleeds
  • 10
Message 8 of 17
I've ordered 2 new CAT 6 cables to replace the modem to router and router to PC as the PC one is old.
PC network card driver is up to date and in 1Gbps mode.
When you say "In the Hub Settings - Connected Devices, what is the indicated connection* speed ?" do you mean on the TPlink Archer A7 settings?
They show:
 PortStatusNegotiation Speed
Link to hub3InternetConnected1000Mbps full duplex
PCLAN1Connected1000Mbps full duplex
Now TVLAN2Connected10Mbps half duplex
XBOXLAN3Connected1000Mbps full duplex
 LAN4Disconnected
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 17
Those figures are showing Hub 3 to TP Link as 1000Mbs.
TP Link to PC as 1000Mbs.
Those figures indicate that the hardware isn't causing a problem.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mattcleeds
  • 10
Message 10 of 17
The Check Service Status link and phone number both say no issues in the area
all co-ax tight. I did want to check that its ok that my hub has a 10dB forward path attenuator inline?
I've setup BQM BQM link
Check Router Status page results:
1402750000-1.240256 qam30
2202750000140256 qam9
32107500000.740256 qam10
42187500000.540256 qam11
52267500000.240256 qam12
62347500000.440256 qam13
72427500000.540256 qam14
82507500000.740256 qam15
92587500000.540256 qam16
102667500000.540256 qam17
112747500000.240256 qam18
122827500000.240256 qam19
132907500000.240256 qam20
142987500000.240256 qam21
153067500000.240256 qam22
163147500000.240256 qam23
17322750000040256 qam24
18330750000-0.740256 qam25
19370750000-140256 qam26
20378750000-1.240256 qam27
21386750000-140256 qam28
22394750000-140256 qam29
23410750000-0.940256 qam31
24418750000-140256 qam32
1Locked40.9130
2Locked40.370
3Locked40.980
4Locked40.940
5Locked40.960
6Locked40.970
7Locked40.950
8Locked40.970
9Locked40.990
10Locked40.950
11Locked40.9110
12Locked40.390
13Locked40.990
14Locked40.970
15Locked40.980
16Locked40.380
17Locked40.950
18Locked40.380
19Locked40.960
20Locked40.9210
21Locked40.3120
22Locked40.9140
23Locked40.350
24Locked40.95
0
1462000363.6512064 qam1
2258000213.4512064 qam4
3326000043.45512064 qam3
4394000173.6512064 qam2
3ATDMA0000
4ATDMA0000
cont...
