lewiement
  • 16
Upgraded from M100 to M200 - no change in speed
I upgraded from the M100 to the M200 earlier on today, and although my upload has increased to the advertised 20mbps, my download is still around 95mbps wired and a little less when wireless.
Should I wait a bit longer before I should see the increase in download? My hub settings do say it should be configured for the M200 after doing some research.
Any help would be appreciated,
Tags (2)
conman33158
  • 1.55K
  • 130
  • 294
Super solver
Re: Upgraded from M100 to M200 - no change in speed
Are you using a Cat 5e cable or above when testing wired speed direct from the router to PC and has your PC got a 1Gbps capable network card?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
lewiement
  • 16
I have just realised I was using the wrong type of cable! Thank you for the messages however!
