AndersLimpar
  • 7
Message 1 of 11
Upgraded and speed has dropped
We upgraded to M500 which kicked in just over 24 hours ago but the speeds have reduced dramatically.
We were on M300 and we were getting speeds of around 220 on wifi, but since the upgrade we now only getting 20 - 30!
Been trying to call virgin but can't get through...
What's the best thing to do?
AndersLimpar
  • 7
Message 2 of 11
Re: Upgraded and speed has dropped
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID197650
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID197649
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 11
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 11
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 11
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
AndersLimpar
  • 7
Message 6 of 11
1138750000-1.740256 qam1
2146750000-240256 qam2
3154750000-2.540256 qam3
4162750000-2.240256 qam4
5170750000-2.240256 qam5
6178750000-2.540256 qam6
7186750000-2.240256 qam7
8194750000-2.240256 qam8
9202750000-2.740256 qam9
10210750000-2.540256 qam10
11218750000-2.740256 qam11
12226750000-2.940256 qam12
13234750000-340256 qam13
14242750000-340256 qam14
15250750000-340256 qam15
16258750000-340256 qam16
17266750000-340256 qam17
18274750000-2.740256 qam18
19282750000-2.740256 qam19
20290750000-2.740256 qam20
21298750000-2.740256 qam21
22306750000-2.740256 qam22
23314750000-340256 qam23
24322750000-3.240256 qam24
1Locked40.923999613635078
2Locked40.32134122253935
3Locked40.928264232181226
4Locked40.927883353373828
5Locked40.3136238830285
6Locked40.912603372
7Locked40.912870723
8Locked40.3196027443
9Locked40.946037745
10Locked40.914882613
11Locked40.911481246
12Locked40.9107118350
13Locked40.920795252
14Locked40.35287109
15Locked40.9347613
16Locked40.3115343
17Locked40.3555898825
18Locked40.9101725102
19Locked40.39070
20Locked40.910240
21Locked40.35790
22Locked40.94970
23Locked40.95320
24Locked40.96100
AndersLimpar
  • 7
Message 7 of 11
14620000049.8512064 qam2
23260000048.3512064 qam4
35370000049.8512064 qam1
43940000049512064 qam3
1ATDMA0070
2ATDMA002
AndersLimpar
  • 7
Message 8 of 11
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID197650
Min Traffic Rate0
SFID197649
Min Traffic Rate0
AndersLimpar
  • 7
Message 9 of 11
10/01/2021 14:43:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:43:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:42:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:42:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:41:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:41:40noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:37:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:37:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:35:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:35:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:33:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:33:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:32:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:31:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:29:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:29:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:28:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:26:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:24:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 14:24:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
AndersLimpar
  • 7
Message 10 of 11
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9be822c4b1f3bfa3c13d0229ee9077a9bdfc3263
