Try a pinhole reset first - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
When its up and running see if speeds are increased. If not log into the settings and navigate to the Configuration File/Data page and look for the Downstream & Upstream boxes for "Maximum Data Transfer Rate" and note what the numbers are (in bps) see if they correspond to a 200 or 350 package
