Upgrade help
RLOJ
I yesterday got the router for hub 5 I set it up everything was OK.
Soon as I turned it on and everything it was still 200mpbs with 20 upload i looked online and some people/suggest to wait 24hrs sometimes will take to upgrade.
It has been 24hrs now or more and I have reset it and other things (including pinhole thingi reset) and that's not made a difference I tried this a couple hours ago to see if it would work and it didn't.
I have tried wired it was the same (the device supports the amount 1gb,2.5gb ethernet,etc) wireless the same thing. I know that ethernet Is more stable blah blah blah
I also heard that it could take 48hrs but I heard that usually doesn't work from people on the community thing and friends and other people
On the 192.168.0.1 virgin media website where you can see things logged in and out it shows (image attached below)   
  • If needed will provide the account ip,email or whatever is needed
I hope to see the upgrade soon (friends who have virgin media had the same issue and then someone helped out by changing or doing something in the weird 192.168.0.1 thingi I think it was a employee/or mod and they had about 1-3hrs after talking that they had the speeds fixed or at least somewhat
7 REPLIES 7
RLOJ
Also here is some other images.
All unreadable
Copy the data as text and paste it into the message
carl_pearce
Super solver
What have you 'upgraded' to?
Your HUB is setup for a M200 subscription, so 200Mbps down / 20Mbps up is correct.
Just because you have a HUB 5 doesn't mean you'll get faster speeds.
UPSTREAM :
160300000465120QAM 641
25370000045.55120QAM 642
34620000045.55120QAM 643
43940000045.55120QAM 644
3ATDMA0000
4ATDMA0000
DOWNSTREAM :
11390000005.442QAM 2561
21470000005.542QAM 2562
31550000005.542QAM 2563
41630000005.442QAM 2564
51710000005.342QAM 2565
61790000005.342QAM 2566
71870000005.142QAM 2567
81950000005.242QAM 2568
92030000004.142QAM 2569
102110000003.341QAM 25610
11219000000542QAM 25611
122270000005.542QAM 25612
132350000005.742QAM 25613
142430000005.742QAM 25614
152510000005.642QAM 25615
162590000005.642QAM 25616
172670000005.542QAM 25617
182750000005.742QAM 25618
192830000005.742QAM 25619
202910000005.942QAM 25620
212990000005.742QAM 25621
223070000005.642QAM 25622
233150000005.542QAM 25623
243230000005.342QAM 25624
253310000005.442QAM 25625
263390000005.442QAM 25626
273470000005.442QAM 25627
283550000005.442QAM 25628
293630000005.342QAM 25629
303710000005.142QAM 25630
313790000005.142QAM 25631
1Locked4204
2Locked4201
3Locked4202
4Locked4200
5Locked4201
6Locked4200
7Locked4200
8Locked4201
9Locked4202
10Locked4101
11Locked4200
12Locked4200
13Locked4200
14Locked4201
15Locked4200
16Locked4202
17Locked4200
18Locked4200
19Locked4201
20Locked4201
21Locked4202
22Locked4205
23Locked4205
24Locked4209
25Locked4204
26Locked4209
27Locked4203
28Locked42010
29Locked42010
30Locked4208
31Locked42019
CONFIGURATION : :
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
1
Enabled
3.1
wrkldJKDHSUBsgvca69834ncx
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
10394
230000061 bps
42600 bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
10391
22000061 bps
42600 bytes
0 bps
42600 bytes
Best Effort
note (less relevant
Had 200almpbs virgin media one aka hub 3 before got hub 5
i know my area can reach 500-1000 (both from neighbours,online tests of ... and other things)
i forgot to say that i know that virgin media upgrading doesnt guarentee the speed to increase
What speed are you subscribed to?
If you haven't updated your subscription from M200 there is nothing wrong. Your speed won't change just because you have a HUB 5!
@RLOJ
As the others have said, the configuration on the hub is set at the 200 Mb/s tier. Now just because VM have ‘upgraded’ you to a hub 5 (and I’ll reserve judgement on the word upgraded here), doesn’t mean there will necessarily be any change in speed, did you upgrade your subscription and are you paying extra for a speed increase?
