ThundermouseUK
  • 7
Message 1 of 10
Upgrade from 200 to M500 but speed is not what I expect
Have upgraded from 200 to M500 and the download speed has improved but not as much as I hoped.  On 200 I could run a speed test and get anything between 180 to 210 but now get up to 280,
My Virgin Media says M500 now
Hub 3 is in router mode and I connected by ethernet cable.
Config looks like it has the updated downstream details
Downstream channels.
Am I missing something or should I expect to get closer to 500 downloads.
ThundermouseUK
  • 7
Message 2 of 10
Re: Upgrade from 200 to M500 but speed is not what I expect
Forgot to add network log
ThundermouseUK
  • 7
Message 3 of 10
And upstream items in case they affect download speeds
  • 6.1K
  • 512
  • 1.57K
Message 4 of 10
From the photos I can see so far, your Downstream power is too low.  Range should be -6 to +10 This will need a VM technician to sort out.
You would be better to copy and paste the information as photos need to be approved and take a while to be visible.
EDIT - Upstream is too high as well. Range should be 34 to 51.
Phone it in to VM or wait here a day or two for a VM Mod to respond.
ThundermouseUK
  • 7
Message 5 of 10
Couple of follow on questions.  Is there a way of tagging the post for a VM Mod to see and to resolve the issue does it usually involve accessing the wiring in the house or would it be at a junction box etc.?
ThundermouseUK
  • 7
Message 6 of 10
carl_pearce
  • 1.44K
  • 93
  • 317
Knows their stuff
Message 7 of 10
It depends on the issue. Power levels are usually adjusted in the cabinet.
It can take 2 days to a week for a reponse from VM on here.
ThundermouseUK
  • 7
Message 8 of 10
Have spoken to VM on phone and changed hub from modem mode back to router mode and speed is now at levels that I would expect with Sam Knows site showing 534 download.  Otherwise network configuration is the same.
Not sure on why this would be but worth trying if you are having the same issue.
ThundermouseUK
  • 7
Message 9 of 10
Power levels are still showing the same BTW
David_Bn
  • 8.66K
  • 361
  • 669
Message 10 of 10
Good Afternoon @ThundermouseUK, thanks for your post and I'm sorry we've not been able to get to this sooner for you
Check out the purple envelope in the top right hand corner for a private message from me
Kindest regards,
David_Bn
