Upgrade but no increase in speed
Hi all,
One of many post on speed but thought I'd drop in my information of anyone would be kind enough to look at the figures.
Ive recently upgraded (last week) to the M200 package.  Prior to that I was on the M100 package and achieving speeds between 75 and 100 Mbps.
Since the upgrade I'm seeing speeds that vary between 65 and 75 Mbps.
I have contacted support, ran through all the usual tests.  I've been told the will send a signal down the line and in 15 mins it will all be working fine! lol
I'm testing on wired ethernet to an iMac using Chrome and Cat5e.
The thing thats most disappointing is I've actually seen a decrease!!
Here are some figures...thanks in advance for any advice, but from what I've read in all of the relevant post, not many actually get to see any improvement.
Cable Modem Status
Item
Status
Comments
323000000
Locked
Ranged Upstream Channel (Hz)
25800000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
6.1
40
256 qam
24
2
139000000
4.4
40
256 qam
1
3
147000000
4.9
40
256 qam
2
4
155000000
5
40
256 qam
3
5
163000000
4.8
40
256 qam
4
6
171000000
4.5
40
256 qam
5
7
179000000
4.5
40
256 qam
6
8
187000000
4.5
40
256 qam
7
9
195000000
4.6
40
256 qam
8
10
203000000
4.9
40
256 qam
9
11
211000000
5.3
40
256 qam
10
12
219000000
5.1
40
256 qam
11
13
227000000
5
40
256 qam
12
14
235000000
5
40
256 qam
13
15
243000000
4.9
40
256 qam
14
16
251000000
5
40
256 qam
15
17
259000000
5
40
256 qam
16
18
267000000
5.3
40
256 qam
17
19
275000000
5.3
40
256 qam
18
20
283000000
5.5
40
256 qam
19
21
291000000
5.6
40
256 qam
20
22
299000000
6
40
256 qam
21
23
307000000
5.9
40
256 qam
22
24
315000000
6
40
256 qam
23
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
9437
161981
2
Locked
40.3
9722
87498
3
Locked
40.3
9292
101007
4
Locked
40.9
8139
99548
5
Locked
40.3
8401
105578
6
Locked
40.3
9162
119626
7
Locked
40.3
9069
131076
8
Locked
40.9
8597
133532
9
Locked
40.3
8318
126375
10
Locked
40.9
8168
124887
11
Locked
40.9
8182
125916
12
Locked
40.9
8233
122995
13
Locked
40.9
9102
133231
14
Locked
40.3
8719
142997
15
Locked
40.3
8506
145316
16
Locked
40.9
7950
139264
17
Locked
40.9
7995
128765
18
Locked
40.3
8286
126413
19
Locked
40.3
8320
127442
20
Locked
40.9
8250
146085
21
Locked
40.9
8246
147994
22
Locked
40.9
8849
154654
23
Locked
40.9
8200
162394
24
Locked
40.9
8797
170416
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
25800000
3.95
5120
64 qam
4
2
46200000
4.125
5120
64 qam
1
3
32600000
4.025
5120
64 qam
3
4
39400000
4.075
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 4.48K
  • 759
  • 1.83K
Re: Upgrade but no increase in speed
Your error levels are too high, and the balance of pre-RS (corrected) errors and post-RS (uncorrected errors) indicates some serious noise problem, despite power levels and measured SNR that are OK.
Nothing you can do other than check that the coax connections to the hub are all finger tight, so do that, chances are that won't make a blind bit of difference, and wait for the forum staff to advise - can be quick, can take a day or two.  If it is a known area problem there will be a fault reference and a fix date, if there's no area fault they'll need to get a technician out to have a look.
The Hub 3 clears its error counters when turned off and on again, so you could do that to see how quickly the error count is rising, but on what you've posted your connection is faulty and needs a field technician to diagnose, find and fix the cause of the fault, which could be as simple as a faulty cable connection, or could be something much more involved like a damaged underground cable.
Thanks for the quick reply.
Coax connection checked..nice and tight.  Hopefully the forum staff won't be too long in responding.
Cheers
  • 1.91K
  • 74
  • 138
Hi heliraptor,
Welcome to the Community and thanks for posting.
I am sorry to hear about the problems you are having with your broadband.
I have taken a look at your account and I'm not seeing any obvious issues on our side.  Going off the stats you have posted, I would like to look at arranging an engineer to come and take a look.
I will pop you over a private message and we can go from there. This will pop in to the purple envelope on the top right of this page.
Nat
