abhachu65
  • 16
Message 1 of 24
Upgrade M300 to M600 Speed slow
I had an upgrade from M300 (hub3) to M600 (hub4).
Since the upgrade the speed has been very slow.
Called Virgin support several times. Had a technician who swapped the hub.
Still the same issue. Wired speed 179mbs - 280MBS
Wireless - 220mbs -  280mbs
Any help please
abhachu65
  • 16
Message 2 of 24
Re: Upgrade M300 to M600 Speed slow
Any help on this please.
The new M600 is running slower then the M300.
Natalie_L
  • 5.13K
  • 195
  • 399
Message 3 of 24
Hi abhachu65,
Welcome to the community and thank you for posting.
I am very sorry to hear you are experiencing issues with the service.
Unfortunately I have been unable to locate your account via the community details to check things from our side but if you could access your Hubs advanced settings and post your network logs, we would be happy to take a look. Information on how to do this can be found here.
You can also run a BQM (Broadband quality monitor) and share your link to this thread 🙂
Nat
abhachu65
  • 16
Message 4 of 24
Hello Nat, thanks I will post the settings.
abhachu65
  • 16
Message 5 of 24
Hi Nat
Here you go.
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 11/09/2021 08:29:525MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 11/09/2021 08:30:186SW Download INIT - Via Config file cmreg-vmdg640-bbt078-b.cm
Sat 11/09/2021 08:31:316SW download Successful - Via Config file
Sat 11/09/2021 08:34:025MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 11/09/2021 09:01:444DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 11/09/2021 22:44:345RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/09/2021 07:17:575MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/09/2021 08:26:045RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/09/2021 18:23:573No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 14/09/2021 00:41:123SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 14/09/2021 00:41:186CM-STATUS message sent. Event Type Code: 5; Chan ID: 21; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/09/2021 08:39:124DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 16/09/2021 04:34:535RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 17/09/2021 03:04:593No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 17/09/2021 07:51:065MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 5.95K
  • 497
  • 1.51K
Message 6 of 24
Please also post the power levels and Pre and PostRS errors from the Hub 4.
abhachu65
  • 16
Message 7 of 24
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.0
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
32
4
DOCSIS 3.1 channels
0
0
abhachu65
  • 16
Message 8 of 24
3.0 Downstream channels
25331000000-0.437.6QAM25625
11390000002.438.6QAM2561
21470000002.437.6QAM2562
31550000002.339QAM2563
41630000001.737.6QAM2564
5171000000137.6QAM2565
61790000000.537.6QAM2566
71870000000.537.6QAM2567
81950000000.337.6QAM2568
92030000000.237.6QAM2569
102110000000.238.6QAM25610
112190000000.338.6QAM25611
122270000000.338.6QAM25612
132350000000.438.6QAM25613
142430000000.438.6QAM25614
152510000000.437.6QAM25615
162590000000.638.6QAM25616
172670000000.637.6QAM25617
182750000000.238.6QAM25618
19283000000-0.238.6QAM25619
20291000000-0.437.4QAM25620
21299000000-0.337.6QAM25621
22307000000-0.138.6QAM25622
23315000000-0.238.6QAM25623
24323000000-0.537.6QAM25624
26339000000-0.838.6QAM25626
27347000000-138.6QAM25627
28355000000-1.138.6QAM25628
29363000000-137.6QAM25629
30371000000-1.237.6QAM25630
31379000000-0.938.6QAM25631
32387000000-0.938.6QAM25632
25Locked37.63627600
1Locked38.60537700
2Locked37.63627600
3Locked38.98326100
4Locked37.63627600
5Locked37.63627600
6Locked37.63627600
7Locked37.63627600
8Locked37.63627600
9Locked37.63627600
10Locked38.60537700
11Locked38.60537700
12Locked38.60537700
13Locked38.60537700
14Locked38.60537700
15Locked37.63627600
16Locked38.60537700
17Locked37.63627600
18Locked38.60537700
19Locked38.60537700
20Locked37.35598800
21Locked37.63627600
22Locked38.60537700
23Locked38.60537700
24Locked37.63627600
26Locked38.60537700
27Locked38.60537700
28Locked38.60537700
29Locked37.63627600
30Locked37.63627600
31Locked38.60537700
32Locked38.60537700
abhachu65
  • 16
Message 9 of 24
3.0 Upstream channels
14620000047.55120 KSym/sec64QAM3
26030000048.55120 KSym/sec64QAM1
353700000485120 KSym/sec64QAM2
43940000047.55120 KSym/sec64QAM4
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
abhachu65
  • 16
Message 10 of 24
