mr2nut123
  • 18
Message 1 of 8
Upgrade - How long?
I upgraded from M100 to M200 over 24 hours ago.  She said it should be almost instant, but still getting M100 on both up/down.  Tried a restart of router, still the same.
How long before this should be active?  I shouldn't imagine there's any training these days and it'll just be a cap that's raised?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Upgrade - How long?
How are you connecting Wi-Fi or ethernet cable ?
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Configuration tab  onto here, if you get a yellow warning click the Post button again.
mr2nut123
  • 18
Message 3 of 8
CAT5.  Don't even use that swear word WiFi again 😉
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
87dsfd;kfoA,.iyewrkldJKDHSUBs
SFID1016
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1015
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Anonymous
Not applicable
Message 4 of 8
Based on your config you are still on 100Mbps.
You could try a full reset (Pin hole for 30 - 60 seconds) to pull in a new config file, however it may not change still.
mr2nut123
  • 18
Message 5 of 8
I definitely don't want to do that, got quite a few port redirects on there so cba setting them back up again.  It would be nice if a tech could check for me, it would be greatly appreciated.  I could do with the increase in the next few days for a stream i've got coming up.
Anonymous
Not applicable
Message 6 of 8
It may happen over night.
You can backup/restore your settings through the Admin/Reload Reboot/Backup & Reload options.
mr2nut123
  • 18
Message 7 of 8
Cheers for that, I'll give it a bash after tonights stream. Thanks for the quick replies Carl.
Anonymous
Not applicable
Message 8 of 8
No worries.
