igorf
Message 1 of 12
Updated to Hub3, performance reduced on wifi dongle
I'm on a 100Mbps broadband only package with a Virgin hub set as router.
After some disruption in my area I wanted to be sure I had all the latest technology to pinpoint the cause of internet drops, so I replaced my Hub2 with a Hub3, .
Now while some devices as mobile phones are getting full Mbps speed, my computer is getting half download speed than before. I was able to get 110 Mbps with my Zyxel usb dongle plugged in my pc, now I'm getting 50 to 80 Mbps in Download. Upload seems OK overall.
I tried changing channels from automatic to manual, but that seems to get things worse.
The signal is very strong as I have my pc next to the router room and it's always been like that for years, maybe this new router doesn't like my usb dongle? Can i change settings to make it work properly?
here is the hardware data:
Protocol: Wi-Fi 4 (802.11n)
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 44
Link speed (Receive/Transmit): 600/216 (Mbps)
Manufacturer: ZyXEL Communications Corporation
Description: ZyXEL Dual-Band Wireless N450 USB Adapter
Driver version: 5.1.22.0
jb66
  • 12.27K
  • 911
  • 1.78K
Message 2 of 12
Re: Updated to Hub3, performance reduced on wifi dongle
Your dongle is not very good, its only 802.11n, you really need wifi 5 AC to have a better chance of maxing out your connection
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 12
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the Wi-Fi connected device you used for the speed test ?
igorf
Message 4 of 12
But why I was getting 110mps download with the Hub2 and my actual dongle? I'm just curious.
jb66
  • 12.27K
  • 911
  • 1.78K
Message 5 of 12
Not sure, but its certainly the weakest part of your setup
igorf
Message 6 of 12
Sure, here is the data:
my pc: 263.67 Mps
my mobile: 571.28 Mps
igorf
Message 7 of 12
Do you think any 802.11ac 2.4Ghz / 5Ghz dongle will solve the problem? Is there any other specific needed?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 12
It won't go above 480Mbs used in a USB 2 slot.
USB 3 is rated at 1Gbs.
  • 23.85K
  • 2.53K
  • 4.32K
Message 9 of 12
You were probably connecting on the 5GHz band on the Hub2 as the 2.4 and 5GHz bands have separate SSID's - the Hub3 hasn't - unless you change them to be separate SSID's - so I suspect it connects to the "slower" 2.4 channel
jb66
  • 12.27K
  • 911
  • 1.78K
Message 10 of 12
The OP earlier showed his dongle connected to channel 44, which is 5ghz
