carlvaneijk
Unworkable upload speed
I've got terrible upload speed. So much so, that my macbook keeps resetting it's wifi connection. I can't join any video conferences without it locking up or dropping out.
It's literally impossible to get through on the support number. Help me! Please!
Here's an example straight off the hub 3.
Test off the routerTest off the router
I have a full LAN setup too, and the hard wire speed tests are similar (between 2 and 6MB upload).
I've factory reset the hub, with no change to these readings.
267000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
12670000005.336256 qam17
213900000010.636256 qam1
314700000010.436256 qam2
415500000010.136256 qam3
51630000009.936256 qam4
61710000009.836256 qam5
71790000009.536256 qam6
81870000009.136256 qam7
91950000008.936256 qam8
102030000008.336256 qam9
112110000008.336256 qam10
12219000000836256 qam11
132270000007.936256 qam12
142350000007.836256 qam13
152430000007.536256 qam14
162510000007.136256 qam15
172590000006.536256 qam16
182750000006.536256 qam18
192830000007.337256 qam19
202910000006.937256 qam20
212990000006.937256 qam21
223070000006.537256 qam22
233150000006.537256 qam23
243230000006.636256 qam24
1Locked36.650
2Locked36.3150
3Locked36.3280
4Locked36.3160
5Locked36.3190
6Locked36.360
7Locked36.390
8Locked36.660
9Locked36.360
10Locked36.680
11Locked36.360
12Locked36.6210
13Locked36.6160
14Locked36.650
15Locked36.670
16Locked36.650
17Locked36.6130
18Locked36.6100
19Locked37.380
20Locked37.3110
21Locked37.390
22Locked37.690
23Locked37.3560
24Locked36.62950
16030000036.3512064 qam1
24620000036512064 qam3
35370000036512064 qam2
43940000036512064 qam4
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID685672
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID685671
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Network LogTime Priority Description
11/02/2021 10:33:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 10:26:59noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 11:42:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 11:34:56noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 10:45:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2021 11:12:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 17:31:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 22:54:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 05:31:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 00:37:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:31:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 13:16:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 05:31:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 21:52:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 17:31:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 16:17:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 23:46:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 01:23:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 01:16:55criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I've also set up the BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/775267edc4262812e415fc134adec0a5be41617a-11-02-2021
Tags (3)
audetto74
  • 143
  • 17
Dialled in
Re: Unworkable upload speed
Does it work better at night? over weekends? What about next week? It is half term here.
Answers to these questions will likely tell what type of problem you have.
carlvaneijk
I don't have a precise date when it started, but around the 4th of February.
Today has been particular bad. My Macbook as been resetting it's wifi constantly.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9d064163d6b1a61f78ba5ffd0c4237978ebb43fe-15-02-2021
It does appear to be better overnight ( according to my speedtester), but I don't use it as much at night.
