Unusable connection with lot of dropouts & high latency
SDESIL
Having horrendous connections issues last four to six months, continuous connection  dropouts & high latency. with "SYNC Timing Synchronization failures" "RCS Partial Service" & "No Ranging Response received - T3 time-out" errors.
had couple of engineer visits with out a luck. Where I go from hear   ???????
28/05/2022 17:51:4
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0;
28/05/2022 17:50:36
Warning!
RCS Partial Service;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0;
28/05/2022 17:50:33
critical
No Ranging Response received - T3 time-out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0;
28/05/2022 17:48:30
Warning!
28/05/2022 17:48:5
critical
28/05/2022 17:47:31
Warning!
28/05/2022 17:46:5
notice
LAN login Success;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0;
28/05/2022 17:42:36
Warning!
28/05/2022 17:42:25
notice
28/05/2022 17:41:56
Warning!
28/05/2022 17:41:6
critical
28/05/2022 17:36:43
Warning!
28/05/2022 17:36:39
critical
28/05/2022 17:34:20
Warning!
28/05/2022 17:34:13
critical
28/05/2022 17:32:53
Warning!
28/05/2022 17:32:51
critical
28/05/2022 17:30:32
Warning!
28/05/2022 17:29:56
critical
28/05/2022 17:28:38
Warning!
4 REPLIES 4
SDESIL
Spoiler
28/05/2022 17:51:4
critical
28/05/2022 17:50:36
Warning!
28/05/2022 17:50:33
critical
28/05/2022 17:48:30
Warning!
28/05/2022 17:48:5
critical
28/05/2022 17:47:31
Warning!
28/05/2022 17:46:5
notice
28/05/2022 17:42:36
Warning!
28/05/2022 17:42:25
notice
28/05/2022 17:41:56
Warning!
28/05/2022 17:41:6
critical
28/05/2022 17:36:43
Warning!
28/05/2022 17:36:39
critical
28/05/2022 17:34:20
Warning!
28/05/2022 17:34:13
critical
28/05/2022 17:32:53
Warning!
28/05/2022 17:32:51
critical
28/05/2022 17:30:32
Warning!
28/05/2022 17:29:56
critical
28/05/2022 17:28:38
Warning!
Post up the tables of data from the Downstream and Upstream pages as well.
Is the Hub in normal router mode or is it in modem mode?
What equipment have you got connected to the Hub on ethernet cables?
Thanks for your reply.
Hub 3 used to be in the modem mode (with a a Cisco device doing the routing) but now put back to router mode.
Most of the desktops and TV's are wired and testing done using wired devices. (also included todays BQM graph)
11387500006.840256 qam1
21467500006.637256 qam2
31547500007.337256 qam3
41627500006.437256 qam4
5170750000536256 qam5
6178750000637256 qam6
71867500006.437256 qam7
81947500004.338256 qam8
92027500004.838256 qam9
102107500005.840256 qam10
112187500003.736256 qam11
122267500003.536256 qam12
132347500004.838256 qam13
142427500003.940256 qam14
152507500002.540256 qam15
162587500003.538256 qam16
172667500004.340256 qam17
182747500002.538256 qam18
192827500002.238256 qam19
202907500003.740256 qam20
212987500002.938256 qam21
223067500001.238256 qam22
233147500002.238256 qam23
243227500002.538256 qam24
1Locked40.3172716415313521
2Locked37.630495932334637
3Locked37.332904972119695
4Locked37.31512245111040505
5Locked36.622081272145298
6Locked37.3107282858856795
7Locked37.35844398900581
8Locked38.91362276533979
9Locked38.9988004424804
10Locked40.3447296264223
11Locked36.3910911363048
12Locked36.31821282471253
13Locked38.9691492356116
14Locked40.3685576208809
15Locked40.3974704411258
16Locked38.9969408399823
17Locked40.3482675292003
18Locked38.9912414423899
19Locked38.9981576440548
20Locked40.3502856346710
21Locked38.9747442249062
22Locked38.61220975483746
23Locked38.9583372338668
24Locked38.646926295830
15370000044.8512064 qam2
26029997145512064 qam1
33940000044.5512064 qam4
44620000044.3512064 qam3
1ATDMA0020
2ATDMA0080
3ATDMA0030
4ATDMA00150
Hey SDESIL, thank you for reaching out and a warm welcome to our community. I am sorry to see you've been having some connection issues for past few months now.
I've take a look on our side and I found an issues  which is an ongoing connectivity issues, so I need to organise a engineer visit for you.
Please look out for the purple envelope I am going to PM you. Thanks
Matt - Forum Team
New around here?
