darrencftse
Unstable internet speed
Lately I've been having some issue with my Virgin internet, playing games i seem to lose connection or it seem slow, today (16/06) i did a speed test and i was shocked in what the results was, the lowest i got was 50mbps when my speed should be 200mbps
Also some of the TV channels would sometime be pixelated, i thought it was due to the weather we been having but i think it might be bigger issue here
  • 2.95K
  • 155
  • 451
jpeg1
Trouble shooter
Re: Unstable internet speed
Are your games device and TV connected directly to the Hub, or by WiFi?
If you get these problems with a wired connection it's likely to be a VM circuit fault that you should report on 150. If you are using WiFi then you should look at the WiFi help posts to see how you can improve it.
darrencftse
My game devices are on wireless, but when i did the speedtest that was on my PC connected directly to the hub
I think i will have to report it.
  • 2.95K
  • 155
  • 451
jpeg1
Trouble shooter
To get the full speed your PC must be connected on 1Gb ethernet, which most modern PCs are capable of. It's just worth checking that in Network Properties before reporting it as a fault
