UnhappyLarry
  • 13
Message 1 of 23
Unreliable connection
I am a customer paying for 200mbps and I am getting 2mbps and no support.
Constantly getting slow speeds I have investigated and removed wifi from the equation by using only a direct LAN connected laptop - plugged directly into the router.
Using speedtest.net and Google speed test I can see my speeds are up and down like a jockey competing in the grand national. Just prior to sending this message I was obtaining the amazing 2mbps speed and a few minutes later this was 46mbps. Next test gave 9.69 Mbps.
I AM PAYING OVER £100 a MONTH FOR AN UNUSABLE SERVICE AND NO SUPPORT!
B63 POSTCODE. No shown faults.
JitteryPinger
  • 1.73K
  • 189
  • 348
Super solver
Message 2 of 23
Re: Unreliable connection
Sorry to see you issues, this is most likely due to a utilization fault in your area (because so many people at home), if you hang on here for a few days someone from the team will reach out and take a look in the meantime you could help us help you by setting up a Broadband Quality Monitor, I'll share a link below of where to do this.
If you need any further help doing this give me a shout, once you have created the monitor share a live direct link back here.
If I've helped please let me know 🙂 Matt
A 10+ Year Virgin Media veteran, been here through the Up's and the Down's and Down's....
Gigabit 5G Vodafone 5G EE BQM Hub 4 BQM Hub 3 BQM Hitron CGNV4 BQM TT BQM
Technical Support - AV & Networking - Customer Service - Finance - Culinary - Construction
UnhappyLarry
  • 13
Message 3 of 23
Thank you.
If that happened I would be very happy.
I have created that monitor as you suggested.
JitteryPinger
  • 1.73K
  • 189
  • 348
Super solver
Message 4 of 23
Great, could you click on Share Live Graph and then copy the Direct Link into a reply.
UnhappyLarry
  • 13
Message 5 of 23
JitteryPinger
  • 1.73K
  • 189
  • 348
Super solver
Message 6 of 23
thanks for sharing, I'll check back on it in a little while and update but so far looks ok, so maybe milder issues to what I was thinking.
UnhappyLarry
  • 13
Message 7 of 23
What do I have to leave on for the test?
I presume obviously the router but does my laptop have to stay connected to that site too?
JitteryPinger
  • 1.73K
  • 189
  • 348
Super solver
Message 8 of 23
Just the router, all the test does is send a ping to the hub and back to a server and measures the time it takes, quicker the better obviously
UnhappyLarry
  • 13
Message 9 of 23
So when will anyone contact me?
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 10 of 23
VM forum staffers usually take 5 - 10 days to respond.
Your BQM looks OK to me - bit of packet loss, but otherwise pretty clean..
Please can you post up your router stats - browse to your hub on http://192.168.0.1 - don't log in, click on "router status" and copy/paste the tables from the Upstream, Downstream and Network Log tabs back here - you'll need to do each table in its own post - it's too big to put them all in one..
