AstoranSolaire
Unreliable Upload speed
Throughout the day at seemingly random intervals my upload speed will suddenly completely drop off for variable periods, usually 5-10 minutes. In normal conditions I get around 220Mb down and 20Mb up but in these periods the up speed remains the same however the down can get as low as 0.5Mb. As I am streaming on Twitch, this has a massive effect on my ability to have a reliable stream as I never know if I am going to get two hours of perfect connection, two hours of nothing or something in between.
Anonymous
Not applicable
Re: Unreliable Upload speed
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
We can check from the stats if there is a local issue with your connection.
