FedRightUp
Under 1mb Upload Speed
I'm a long time virginmedia customer, but now I've been forced onto a message board to find help. I've called up and registered complaints with the offshore call centre but nothing at all has changed. At the moment a slow reliable line would be better than a fast one that doesn't work,
I'm supposed to have a 350mb down and 36mb up line , which has been generally okay but in the last three weeks there hasn't been a problem free day.
This morning the line was down due to a power cut and then nothing from 8pm this evening. If anyone here can help please let me know.
Here are some of the details from my router
Upstream details
Channel Frequency (Hz)Power (dBmV)Symbol Rate (ksps)Modulation Channel ID
1326000004.225512016 qam29
2393999284.2512064 qam28
3462000004.204512032 qam27
4536998594.275512064 qam26
Channel Frequency (Hz)Power (dBmV)SNR (dB)ModulationChannel ID
1203000000-0.233256 qam9
2211000000-0.432256 qam10
3219000000-0.535256 qam11
4227000000-0.536256 qam12
5235000000-0.537256 qam13
6243000000-0.736256 qam14
7251000000-0.736256 qam15
8259000000-0.736256 qam16
9267000000-136256 qam17
10275000000-0.936256 qam18
11283000000-0.736256 qam19
12291000000-0.536256 qam20
13299000000-0.436256 qam21
14307000000-0.536256 qam22
15315000000-0.536256 qam23
16323000000-0.736256 qam24
17427000000-1.736256 qam25
18435000000-1.436256 qam26
19443000000-136256 qam27
20451000000-136256 qam28
21459000000-1.536256 qam29
22467000000-1.735256 qam30
23475000000-1.736256 qam31
24483000000-1.436256 qam32
Channel Locked Status RxMER (dB)Pre RS ErrorsPost RS Errors
1Locked33.81129720
2Locked32.910364320
3Locked35.76624
4Locked36.61225
5Locked37.32023
6Locked36.61031
7Locked36.6925
8Locked36.61362
9Locked36.619101
10Locked36.62129
11Locked36.61929
12Locked36.61025
13Locked36.62135
14Locked36.61041
15Locked36.33179
16Locked36.63618
17Locked36.31735
18Locked36.34734
19Locked36.33827
20Locked36.64526
21Locked36.63732
22Locked35.74533
23Locked36.35452
24Locked36.34517
Errors in the log
10/06/2020 21:51:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2020 21:49:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2020 20:23:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2020 20:23:53criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2020 19:02:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2020 19:01:44noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:34:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 10:29:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 08:41:10Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 02:58:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 13:59:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 13:59:36Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 13:59:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 10:34:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 07:41:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 22:25:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 18:10:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 03:03:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 02:34:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 01:26:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
If anyone at all can help that would be great as one more day lost and I'll have to get a backup broad line in.
Tags (1)
Andrew-G
  • 6.13K
  • 1.08K
  • 2.6K
Re: Under 1mb Upload Speed
The variation in the upstream modulation indicates an upstream noise problem and explains the slow speeds,  but you've also got power levels that are too low on a couple of downstream channels that is causing high error counts.  This will need a technician visit to fix, if you hold on here the forum staff will pick this up and advise on next steps.  That can take minutes, sometimes a day or two, but always better to deal with the helpful UK forum staff than phone in and deal with the untrained script readers of Timbuktoo.
Steven_L
  • 4.62K
  • 338
  • 460
Hey FedRightUp.
I agree with what Andruser has said, you will need an engineer visit for to fix your issue.
I will drop over a private message in a few moments, please respond and we can get this sorted.
Steven_L
