oliW4
  • 5
Unacceptable speed drops
I'm facing exactly the same issue, with very similar speeds (5-10 Mbit/s) on a >500 Mbit/s connection unless I restart the router every night.
Can you please get this fixed for me too?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Unacceptable speed drops
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
oliW4
  • 5
Thanks - I'll get back to you in mid January. Left London this morning and won't be back before the new year!
