lftelo
Ultra slow speeds for 1GB
A month ago I “upgraded” from 500MB hub 3 (was getting speeds to 350 - 400 MB) to the 1GB hub 4 (at an additional GBP30 cost for the new hub). I have raised numerous complaints over the past few weeks that I have only been getting speeds of 100 - 200 MB on the new “improved” fibre package.
I was told by Virgin support that they need to push some software update in order to improve speeds. Anyone else that has experienced such dissatisfaction or can help resolve?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Ultra slow speeds for 1GB
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
