Cuthbertero
Message 1 of 9
The influence of weather on wifi transmission quality
After heavy rains, my wifi was affected again. I can't watch music videos, songs and movies on youtube. When I read the newspaper, the network quality did not meet my needs. Can you share me some methods that can fix this problem?
Anonymous
Not applicable
Message 2 of 9
Re: The influence of weather on wifi transmission quality
Rain doesn't affect Wifi, unless you are outside in the rain or the Wifi has to travel through rain between your device and HUB.
  • 2.89K
  • 217
  • 616
Trouble shooter
Message 3 of 9
It does if it affects the infrastructure.  This happened to me as the CAB was being flooded. Fortunately the engineers were quick to fix the Cabinet and stop the water ingress.
But yes, it will not affect wifi as such, but will impact the broadband circuit supply to the house.
Anonymous
Not applicable
Message 4 of 9
An extreme yet well presented example that I didn't have in mind!
Corey_C
  • 3.42K
  • 185
  • 269
Message 5 of 9
Hi Cuthbertero,
Thanks for your post and welcome to the community forums. Sorry to hear that you are having WIFI issues. Can you confirm if you are having the same issues on your wired connections?
Cheers,
Corey C
Cuthbertero
Message 6 of 9
Thanks to everyone's sharing, I have fixed the problem
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
What did you do to fix the problem ?
Corey_C
  • 3.42K
  • 185
  • 269
Message 8 of 9
Hi Cuthbertero,
Glad you hear you've fixed it
Cheers,
Corey C
jem101
  • 1.62K
  • 229
  • 756
Message 9 of 9
One thing that this thread indicates is that for many people wifi and internet connectivity are synonymous. Which is why one of the first things to ask (if not the first) when answering someone complaining that 'my internet doesn't work'* is 'is this a wifi connection and if so are any direct wired machines also effected. There's no point looking into wifi issues without first seeing if the problem isn't with the internet feed itself.
* Every time I see that statement, I'm always half-tempted to respond with 'wow you have your own internet - are you actually Vint Cerf?'😉
