RideTheSkye
Terrible upload speeds and not getting full download speed during prime time
Hi there. I have noticed the past few days that the upload speeds that I am getting are absolutely terrible, and during prime time my download speeds are roughly half of what I should be getting. I am on the M600 package and during the day I roughly get 300mbps down. My upload speeds seem to be around 1mbps no matter what time of the day and is the real problem right now. These speeds are measured from my PC over a wired connection using a suitable cable.
I started a BQM last night at around 2am so that is attached: My BQM
RideTheSkye
Re: Terrible upload speeds and not getting full download speed during prime time
Here is the data from our hub:
1203000000-1.240256 qam9
2211000000-1.540256 qam10
3219000000-1.440256 qam11
4227000000-1.540256 qam12
5235000000-1.440256 qam13
6243000000-1.740256 qam14
7251000000-1.740256 qam15
8259000000-1.940256 qam16
9267000000-1.940256 qam17
10275000000-1.540256 qam18
11283000000-0.940256 qam19
12291000000-0.940256 qam20
13299000000040256 qam21
143070000000.440256 qam22
153150000000.440256 qam23
163230000000.240256 qam24
17363000000040256 qam25
18371000000040256 qam26
19379000000040256 qam27
20387000000-0.540256 qam28
21395000000-0.540256 qam29
22403000000-0.740256 qam30
23411000000-0.940256 qam31
24419000000-0.740256 qam32
1Locked40.3270
2Locked40.9200
3Locked40.990
4Locked40.9120
5Locked40.3190
6Locked40.3120
7Locked40.9170
8Locked40.9740
9Locked40.9210
10Locked40.3200
11Locked40.3190
12Locked40.9200
13Locked40.3150
14Locked40.3300
15Locked40.9110
16Locked40.9300
17Locked40.9120
18Locked40.9120
19Locked40.9280
20Locked40.3290
21Locked40.990
22Locked40.9200
23Locked40.3210
24Locked40.3110
16030004152512016 qam1
24619962552512016 qam3
33940019052512016 qam4
45370003252512016 qam2
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt078-b.cm
SFID330008
Max Traffic Rate690000278
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID330007
Max Traffic Rate44000278
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
RideTheSkye
14/01/2021 02:24:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 02:24:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 02:23:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 02:22:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 00:25:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 11:28:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 12:29:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 23:28:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 18:13:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 11:28:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 06:52:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 16:58:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 16:59:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 23:32:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 04:59:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 19:22:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 16:59:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2020 06:09:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2020 00:27:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Your Upstream Power Levels are too high and all four of the modulations are at 16 QAM, thyey should be 64 QAM.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
