Sign in
Sign out
on 12-02-2023 12:19
Only getting 40mb
I am on M200
this is ridiculous why should I pay for a speed I don’t even get?
if this doesn’t improve I am leaving without a cancellation fee 🙃
on 12-02-2023 12:27
"the speed you get" = "the speed the device draws"40Mb/s suggests the results are of a WiFi device connected at 2.4Ghz.To find the speed to the Hub and also of the device try the link below.Once the test begins, click on Run full test to the upstream speeds. https://www.samknows.com/realspeed/
on 12-02-2023 12:31
It says 350 router - 350 device
can I turn 2.4 off through my wifi?
on 12-02-2023 12:43
350 router - 350 device is fine. You don't need to do anything.Don't turn the 2.4Ghz WiFi off on the Hub, 2.4Ghz provides a longer range service for when the device is out of range for 5GHz.
Just managed to turn it off
