magmp
  • 18
Message 1 of 32
Terrible drops of speed on 1gb tariff
Since I have switched to 1gb tariff my internet speed is dropping every day sometimes to 10Mbps !!! Only way to fix it is to restart a hub which is in modem mode. (Resetting my own router isn't helping). I have to do this sometimes couple times a day!! I called help line and after a auto test auto voice told me to reset a hub#&@!!!! Also it's great that you offering 1.1gb speed when hub over Ethernet has 1gb ports :DDD. Nice marketing trick.
Anonymous
Not applicable
Message 2 of 32
Re: Terrible drops of speed on 1gb tariff
The whole point of a faster connection is to be shared across concurrent devices. You can get 1.1Gbps across multiple devices, wired and wireless, when using the HUB 4. Maybe you should do your research before posting...
risc19
  • 849
  • 27
  • 253
Well-informed
Message 3 of 32
The 1.1gb speed is a bit deceptive, but thats not unusual.
It's normal for routers to add all the bandwidth on the different bands together and say thats the speed.
They are not wrong, but it's a bit unhelpful.
The think with the problem thats going to happen more with the hub4 is overheating. Anything actively cooled is going to get blocked with dust then add a 38c heat wave and watch them fail.
I honestly hope they think about a hub 5 and discontinue the 4.
It was utterly unforgivable to use another router with flawed puma chipset after the puma 6 lawsuit.
My Broadband Ping - Virgin Lagfest Modem Mode
magmp
  • 18
Message 4 of 32
Spoiler
Yes, it's normal for routers to give all together combined speed of WiFi, like my own 2600, but Ethernet is a different story(mine has 2.5Gb port) but you can't achieve a speed for your one device with virgin hub(I might live alone and use only PC for example) and I'm paying for 1145Mb speed as I was promised but 1Gb port won't allow it. For overheating issue, I have 2 independent fans in and out on bottom and top of Hub4 but still not helping. Like I said, speed is dropping everyday and I have to restart a router sometimes few times a day. This is not what I've ordered. I had stable speeds on old hub, but now it's just bad.
risc19
  • 849
  • 27
  • 253
Well-informed
Message 5 of 32
Agreed. They should really have gone with 2.5 g ports for there super duper hub 4. And anything but puma chipset.
They really don't learn, as now there is zero headroom for expansion.
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 6 of 32
The maximum throughput from a Hub 4 with only be 940mb regardless of what your own router can handle, it's just a poor design and should as mentioned at the very least have had 2.5 Gbps ports, but sure it is what it is and we just have to work with it.
As for your problem. Can you please upload your router stats and set up a BQM
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
DO NOT LOG IN, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
magmp
  • 18
Message 7 of 32
253310000004.40000238.605377QAM25625
11390000006.09999838.983261QAM2561
21470000005.50000038.983261QAM2562
31550000005.09999840.366287QAM2563
41630000005.09999840.366287QAM2564
51710000005.19999740.366287QAM2565
61790000005.30000338.983261QAM2566
71870000005.40000238.983261QAM2567
81950000005.59999838.983261QAM2568
92030000005.50000038.983261QAM2569
102110000005.50000040.366287QAM25610
112190000005.40000240.366287QAM25611
122270000005.19999740.366287QAM25612
132350000005.19999740.366287QAM25613
142430000005.19999740.366287QAM25614
152510000004.90000240.366287QAM25615
162590000004.69999738.605377QAM25616
172670000004.90000238.983261QAM25617
182750000004.80000338.983261QAM25618
192830000004.50000038.983261QAM25619
202910000004.09999838.983261QAM25620
212990000003.40000238.983261QAM25621
223070000003.59999838.983261QAM25622
233150000003.79999940.366287QAM25623
243230000004.40000238.983261QAM25624
263710000004.19999738.605377QAM25626
273790000003.90000238.605377QAM25627
283870000003.59999838.605377QAM25628
293950000004.00000038.983261QAM25629
304030000003.70000138.605377QAM25630
314110000003.50000038.605377QAM25631
3.0 Downstream channels
25Locked38.60537700
1Locked38.98326100
2Locked38.98326100
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked38.98326100
7Locked38.98326100
8Locked38.98326120
9Locked38.98326100
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked38.60537700
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked38.98326100
22Locked38.98326100
23Locked40.36628700
24Locked38.98326100
26Locked38.60537700
27Locked38.60537700
28Locked38.60537700
29Locked38.98326100
30Locked38.60537700
31Locked38.60537700
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159884K1720QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked414.94843018530
magmp
  • 18
Message 8 of 32
3.0 Upstream channels
14620000029.5205995120 KSym/sec64QAM3
23260000029.5205995120 KSym/sec64QAM5
33940000029.5205995120 KSym/sec64QAM4
45370000030.0205995120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
magmp
  • 18
Message 9 of 32
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDHSUBs
SFID
29192
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
29191
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
magmp
  • 18
Message 10 of 32
Sun Feb 7 23:12:59 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Feb 8 11:35:11 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Feb 8 20:01:20 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 10 22:24:47 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 10 22:24:47 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Feb 12 00:06:09 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Feb 12 06:41:33 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 14 09:57:16 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 14 09:57:16 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 14 21:26:34 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Feb 15 18:41:54 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Feb 17 11:17:43 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 18 14:19:28 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 18 14:19:28 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 18 21:57:25 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 21 18:38:23 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 21 18:38:23 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 25 02:41:13 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 25 06:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Feb 25 06:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 28 18:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Feb 28 18:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 4 06:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 4 06:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 4 07:20:04 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 7 18:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 7 18:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Mar 10 08:55:09 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 11 06:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 11 06:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 14 18:38:24 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 14 18:38:24 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar 14 23:47:39 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 15 23:02:46 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 18 19:00:59 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 18 19:00:59 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Mar 20 19:10:41 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 22 01:19:46 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 22 01:19:46 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 22 12:46:23 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 25 13:19:46 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 25 13:19:46 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar 25 17:51:05 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 29 08:43:44 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 04:33:35 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 04:33:35 20216DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Mar 31 04:44:52 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Apr 2 03:56:42 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
