Sneaky2
  • 23
Message 1 of 16
Technician visited and wifi not fixed/worse
Internet connection is still really choppy, upload speeds non-existent at times, download speed plummets to around 50mbps and I get massive lag in some games, massive packet loss in the BQM. I've tried restarting, I've had a technician come round and "fix" it, I let virgin know it wasn't fixed and they put me on hold for 2 hours before cutting the line. Please can someone suggest some fixes or some steps? I can't wait on hold again for 2 hours just to be cut off
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 16
Re: Technician visited and wifi not fixed/worse
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 16
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Anonymous
Not applicable
Message 4 of 16
do you have the same problems with a wired connection?
Sneaky2
  • 23
Message 5 of 16
Sneaky2
  • 23
Message 6 of 16
12027500003.738256 qam9
22107500003.538256 qam10
32187500003.238256 qam11
42267500003.238256 qam12
5234750000338256 qam13
62427500002.738256 qam14
72507500002.438256 qam15
8258750000238256 qam16
92667500001.938256 qam17
102747500002.738256 qam18
112827500003.738256 qam19
122907500004.538256 qam20
13298750000538256 qam21
143067500005.338256 qam22
153147500005.538256 qam23
163227500005.538256 qam24
17330750000638256 qam25
183707500006.338256 qam26
193787500005.838256 qam27
20386750000538256 qam28
213947500004.538256 qam29
224027500004.838256 qam30
23410750000538256 qam31
244187500004.938256 qam32
1Locked38.670
2Locked38.6110
3Locked38.650
4Locked38.660
5Locked38.6140
6Locked38.680
7Locked38.6150
8Locked38.9110
9Locked38.6130
10Locked38.6180
11Locked38.6140
12Locked38.6120
13Locked38.670
14Locked38.6250
15Locked38.9210
16Locked38.690
17Locked38.690
18Locked38.960
19Locked38.970
20Locked38.670
21Locked38.990
22Locked38.9150
23Locked38.9110
24Locked38.680
Sneaky2
  • 23
Message 7 of 16
13940000047.5512064 qam9
25370000047.3512064 qam7
34619990346.8512032 qam8
43259987846.7512016 qam10
1ATDMA00140
3ATDMA0010
4ATDMA0020
Sneaky2
  • 23
Message 8 of 16
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID334142
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID334141
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Sneaky2
  • 23
Message 9 of 16
Yes same issues with wired and wireless
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 16
It looks like you have two problems, firstly your BQM is showing latency and lost packets during 'gaming hours', this could account for the Upstream Modulation issues - they should all be at 64 QAM.
Secondly.
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at +1.9dBmV and the highest at +6.3dBmV is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
