Takes for ever to log into hub and run a test connection drops out on everything HELP
james155
Takes forever to log into hub and run a test connection drops out on everything.
Started to notice problems when I was unable to sync to server on farm sim 22
Then the other problem is taking forever to log into the hub and when I run a test within the hub my connection drops out completely. I rang virgin media up 19 hours ago and they said there was no problem.  mmm ?
13310000004.340256 qam25
22030000003.540256 qam9
32110000003.540256 qam10
42190000003.440256 qam11
52270000003.240256 qam12
62350000003.740256 qam13
7243000000440256 qam14
82510000004.540256 qam15
92590000004.540256 qam16
102670000004.440256 qam17
112750000004.140256 qam18
122830000004.440256 qam19
132910000004.640256 qam20
14299000000540256 qam21
15307000000540256 qam22
163150000004.940256 qam23
173230000004.340256 qam24
183390000004.540256 qam26
193470000004.540256 qam27
203550000004.540256 qam28
213630000003.940256 qam29
22371000000440256 qam30
233790000004.340256 qam31
24387000000440256 qam32
9 REPLIES 9
james155
1 Locked 38.9 3700 1265
2 Locked 40.9 38691 5389
3 Locked 40.3 19391 4003
4 Locked 40.3 24032 5925
5 Locked 40.3 58719 5120
6 Locked 40.9 32432 2799
7 Locked 40.3 10863 3801
8 Locked 40.3 5308 3718
9 Locked 40.3 5240 4127
10 Locked 40.3 9125 4274
11 Locked 40.3 19266 2664
12 Locked 40.3 8548 2219
13 Locked 40.3 3452 2448
14 Locked 40.3 3061 2634
15 Locked 40.3 4294 2254
16 Locked 40.9 7731 2425
17 Locked 40.9 12613 3197
18 Locked 40.9 1860 2297
19 Locked 40.3 1907 1417
20 Locked 40.9 2241 1673
21 Locked 40.3 2737 3417
22 Locked 40.9 1627 1362
23 Locked 40.3 1258 1100
24 Locked 40.3 1205 1353
1 46200000 44.8 5120 64 qam 1
2 39400000 44.3 5120 64 qam 2
3 25799966 43.8 5120 64 qam 4
4 32599950 44.8 5120 64 qam 3
1 ATDMA 0 0 1 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
03/01/2022 10:26:46 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 08:36:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 08:35:20 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 06:08:45 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 01:37:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 15:03:38 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 09:34:57 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 09:07:37 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 09:04:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 09:04:52 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2021 01:20:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 12:53:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 09:30:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 03:44:30 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 03:42:36 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 03:42:36 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 02:51:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 02:48:27 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 02:48:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Far too many PostRS errors, there should be none. Reboot the Hub and if these errors mount up again quickly, then VM will need to fix this.
james155
I rebooted it 19 hours ago
Hi @james155
Thanks for posting on our community forum!
How is your connection performing today?
Travis_M
james155
I was able to log into my hub without delay was able to keep connected to a game server which I was unable to do no net speed drops and the network log has no more post RS errors just some critical timeout T3 ones tho. But yeah seems to be running smoothly now.
james155
Well my net went down at around midnight /1am
1 331000000 4.3 38 256 qam 25
2 203000000 3 40 256 qam 9
3 211000000 3.4 40 256 qam 10
4 219000000 3 38 256 qam 11
5 227000000 2.9 40 256 qam 12
6 235000000 3.5 40 256 qam 13
7 243000000 3.5 40 256 qam 14
8 251000000 4.4 40 256 qam 15
9 259000000 4.5 40 256 qam 16
10 267000000 4 40 256 qam 17
11 275000000 4.1 40 256 qam 18
12 283000000 4.4 40 256 qam 19
13 291000000 4.5 40 256 qam 20
14 299000000 5.3 40 256 qam 21
15 307000000 5 40 256 qam 22
16 315000000 4.9 40 256 qam 23
17 323000000 4.4 40 256 qam 24
18 339000000 4.5 40 256 qam 26
19 347000000 4.8 40 256 qam 27
20 355000000 4.6 40 256 qam 28
21 363000000 3.9 40 256 qam 29
22 371000000 4.4 40 256 qam 30
23 379000000 4.3 40 256 qam 31
24 387000000 4 40 256 qam 32
james155
1 Locked 38.6 1 0
2 Locked 40.3 6 0
3 Locked 40.3 6 0
4 Locked 38.9 6 0
5 Locked 40.3 5 0
6 Locked 40.3 7 0
7 Locked 40.3 4 0
8 Locked 40.3 5 0
9 Locked 40.3 6 0
10 Locked 40.3 1 0
11 Locked 40.3 5 0
12 Locked 40.3 5 0
13 Locked 40.3 6 0
14 Locked 40.3 6 0
15 Locked 40.3 6 0
16 Locked 40.3 3 0
17 Locked 40.3 6 0
18 Locked 40.3 5 0
19 Locked 40.9 5 0
20 Locked 40.9 6 0
21 Locked 40.3 1 0
22 Locked 40.3 1 0
23 Locked 40.3 6 0
24 Locked 40.3 0 0
james155
1 46200000 45.8 5120 64 qam 1
2 39400000 44.8 5120 64 qam 2
3 25800000 46.3 5120 64 qam 4
4 32600000 45 5120 64 qam 3
Do I need an engineer out?
Hi @james155,
Sorry to hear you're had some further issues with your service.
I have taken a look at the account and at the time of writing have been unable to identify any issues. There's no issue with your power levels or uptime and no area fault that could be impacting you. As such no technician is required right now.
Kind Regards,
Ayisha_B
