Beau1066
  • 5
Tablet Speed Test
I have 500mbps on all my devices yet the new tablet I bought today never gets above 65mbps, There are only 3 devices online at any one time (Laptop, Phone, Tablet) Phone is sitting idle no downloads as is the laptop. Still never goes above 65, frustrating as I use the tablet for Stadia gaming
jpeg1
  • 7.51K
  • 389
  • 1.46K
Legend
Re: Tablet Speed Test
Which WiFi band is the tablet connecting on?  It needs to be on 5GHz to get the best speeds.  You may have to split the two bands with different SSIDs, and then reconnect the tablet to the 5GHz band.
  • 6.79K
  • 591
  • 1.78K
What make and model is the tablet?
What speed does the laptop achieve with a direct wired connection to the Hub using www.samknows.com/realspeed ?
As suggested by @jpeg1  try splitting the SSID as below;
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
Ashleigh_C
  • 5.27K
  • 193
  • 386
Hi there @Beau1066
Thank you for your post and welcome back to the forums!
I'm so sorry to hear that you are facing this issue with your new device!
Can I just check if you have been able to follow the advise from @Adduxi and @jpeg1
Thank you.
Ash_C
