spear
  • 25
Message 1 of 10
TV speed
Recently purchased an LG TV, OLED C1. Everything with the TV is OK except for the Internet speed. The speed varies between 40-50 mbps and that's with a cable connection between the router and TV. I find that WiFi connetion its about the same and sometimes better. I’ve read online that the connection LG have provided on their tv's can only operate at up to 100 mbps and recommend using an usb adaptor. This I have done and the speed has increased to about 70-80, but cannot understand why I'm not getting at least 100 or even higher with the adaptor. I've checked internet speed using my pc and laptop and both are getting the expected 500 mbps.
I'm trying to establish if the  problem lies with the TV, or has something to do with Internet settings.
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 2 of 10
Re: TV speed
Connected at 100Mbps you'lll see a maximum of 95Mbps including overheads.
Is the USB port you connected to USB 3.0?
spear
  • 25
Message 3 of 10
Re: TV speed
No USB 2.0, no USB's 3.0 available
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 4 of 10
Re: TV speed
USB 2.0 is capable of 480Mbps so you should be seeing faster speeds if your USB ethernet adapter is 1Gbps.
What app are you using for speed testing?
spear
  • 25
Message 5 of 10
Re: TV speed
Ookla
Roger_Gooner
  • 8.74K
  • 558
  • 1.66K
Message 6 of 10
Re: TV speed
Is the firmware up to date?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 7 of 10
Re: TV speed
@spear wrote:
Ookla
Is it an app or through a web browser?
Regardless none of the methods appear very good (I've tried on my older LG OLED).
spear
  • 25
Message 8 of 10
Re: TV speed
The firmware on the TV is up to date, or did you mean the hub?
spear
  • 25
Message 9 of 10
Re: TV speed
It's through the browser....is there a better one that I could try?
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 10 of 10
Re: TV speed
I've tried several that are all as bad as each other, so must be a limitation of the integrated web browser.
I can't find any actual apps in the LG store either!
