Swiftly
TV Pixilation and Lower Internet Speed
Hello Folks
Been having a tv pixilation problems for ages and it thought it was sorted and upgraded the services
Internet on original service was 100mb which seemed fine
should now be getting 350m download speed but only get 200-220mb
HUB 3   and Tivo TV sloped front one.
yep above the minimum service of 181mb for m350 so their not interested
Upload as should be I believe about 36mb
Read up about the downstream level and and think the signal here is to high?
Should be this -6 to +10  Mine 14 to 18 ish
Would you agree and could this be the problem of the pixil problems?
PS have a original 3 way splitter cable in with 2 out of 3 used - 6db print at 3 outputs
Thanks in Advance Folks !!
122700000014.538256 qam12
221900000014.538256 qam11
323500000014.638256 qam13
424300000014.338256 qam14
525100000013.638256 qam15
62590000001338256 qam16
726700000013.938256 qam17
827500000015.338256 qam18
928300000015.840256 qam19
102910000001640256 qam20
1129900000016.438256 qam21
1230700000016.340256 qam22
1331500000016.540256 qam23
1432300000016.540256 qam24
1533100000016.940256 qam25
163710000001840256 qam26
173790000001840256 qam27
1838700000018.140256 qam28
1939500000017.540256 qam29
2040300000016.540256 qam30
2141100000016.340256 qam31
2241900000016.540256 qam32
2342700000016.540256 qam33
2443500000016.640256 qam34
1Locked38.900
2Locked38.900
3Locked38.950
4Locked38.960
5Locked38.960
6Locked38.970
7Locked38.900
8Locked38.940
9Locked40.350
10Locked40.350
11Locked38.960
12Locked40.350
13Locked40.950
14Locked40.300
15Locked40.300
16Locked40.310
17Locked40.350
18Locked40.950
19Locked40.350
20Locked40.300
21Locked40.300
22Locked40.350
23Locked40.300
24Locked40.300
13260000036.8512064 qam3
22580000037.3512064 qam4
34620000036.5512064 qam1
43940000036.5512064 qam2
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: TV Pixilation and Lower Internet Speed
Your Downstream Power Levels are far too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Swiftly
thanks for confirming and replying
Swiftly
Spoke to them can do it remotely    FOR THE FOURTH TIME   YEH OK
Said I didn't believe her
I've fitted new splitter found on internet same make and spec VM use and cables to try Good Quality RG6 etc
With same high readings from hub
Still getting pixilation but may have sorted that a "little"
Readings the same between  +15 and +20 on the download dbmv levels
The main VM Cabinet is outside my house poss why the high signal levels
Not going to let this lie would never treat one of my customers like this
