RonD1
  • 15
Message 1 of 7
TV Makes repeated noises when we first switch it on
We have been with VM for a couple of months now.  After an engineer visit a week ago (hub was rebooting frequently; he increased input signal and all is well now), the TV started making beeping sounds every time we turn it on (see link to video of the sound; sounds like "plililip, plililip, plililip" https://youtu.be/Li3YnPUSzBk .  Any ideas why, and how to stop it please?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: TV Makes repeated noises when we first switch it on
You video isn't available.
How is the TV connected to the Hub, Wi-Fi or ethernet cable ?
RonD1
  • 15
Message 3 of 7
Hi Mike
Thanks for your prompt reply and sorry about the video, which was not uploaded properly for some reason.  The TV is connected to the hub via ethernet cable and is less than one metre away.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
Have you got a different ethernet cable to use ?
It sounds like interference of some sort.
RonD1
  • 15
Message 5 of 7
I think I have now uploaded a proper video this time (the last effort was a converted audio file).  It is not noise and stops after about 10 seconds, and is always the same, so I think it is coming from the hub, some sort of system generated sound.  Our phone is also flashing that it has voicemail messages, whereas we have deleted them all; may be linked?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 7
The TV screen is showing Virgin Media, I take it that the TV is connected to a Virgin TV Box ?
Can you connect the TV Box (if you are using one) to the Hub using Wi-Fi ?
RonD1
  • 15
Message 7 of 7
Yes, the TV is connected to a Virgin TV 360 box, which is connected to the hub via ethernet cable.  Everything works fine, except those sounds when we FIRST switch the TV on.  It's not the end of the world and I am too busy right now to connect the TV box to the hub via wifi.  It was not making that sound before and we have not changed the connection mode (ethernet) or anything else.
