brokenruler
T3 timeouts and intermittent dropouts
Since I can remember, my connection has cut out intermittently at points during the day. Previously it was just a bit annoying, but I’ve recently returned to work from maternity leave and it’s now making it a nightmare to work from home. Any thoughts appreciated.
Channel
Frequency
Power
1
483000000
1.7
2
187000000
2.2
3
195000000
1.7
4
203000000
1.5
5
211000000
1.2
6
219000000
1.4
7
227000000
1.2
8
235000000
0.9
9
243000000
0.4
10
251000000
0
11
259000000
-0.2
12
267000000
0
13
275000000
0.7
14
283000000
1.7
15
291000000
2
16
299000000
2.5
17
307000000
2.7
18
315000000
2.7
19
323000000
2.2
20
443000000
1
21
451000000
0.5
22
459000000
0.2
23
467000000
0.7
24
475000000
1.4
Channel
RxMER (dB)
Pre RS Errors
Post RS Errors
1
38.9
62
0
2
38.9
110
12
3
38.6
108
13
4
38.9
151
24
5
38.6
92
13
6
38.6
77
10
7
38.6
97
14
8
38.9
94
13
9
38.9
87
11
10
38.6
678
14
11
38.6
86
12
12
38.6
91
13
13
38.6
95
4
14
38.6
64
0
15
38.6
87
0
16
38.6
90
0
17
38.9
82
0
18
38.9
101
0
19
38.9
72
0
20
38.9
60
0
21
38.6
113
0
22
38.9
116
0
23
38.9
107
0
24
38.6
103
0
Upstream Bonded Channels
Channel
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
0
0
0
0
2
0
0
0
0
3
0
0
0
0
4
0
0
0
0
Time
Description
27/09/2020 22:32:4
No Ranging Response received - T3 time-out
27/09/2020 01:29:8
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified
27/09/2020 01:29:8
DHCP RENEW WARNING - Field invalid in response v4 option
26/09/2020 11:07:7
26/09/2020 08:01:45
24/09/2020 01:44:22
24/09/2020 01:44:22
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: T3 timeouts and intermittent dropouts
You Network Log hasn't reported anything for two and a half days which is unusual.
Can you reboot your Hub using this exact method ...
Switch the Hub off for 5 minutes using the small switch on the rear of the Hub next to the power cord.
Allow the Hub a few minutes to fully restart then post the Hub data again please.
