jkenti
T3 and T4 timeout errors - slow speeds and occasional drops in internet
Over the last two weeks I have been getting period of slow speeds and occasional internet drops, this is most pronounced when doing video calls (poor or weak connection!!) but today it's been with streaming music. I am on the M100 plan. I looked at the HUB 3 page and noticed a lot of T3 and T4 timeout errors - so I am hoping someone can help?
I have tried resetting the hub several times over the last two weeks, but it doesn't solve the issue. I notice now that I am getting Post RS errors, which is new since I last looked at the HUB last week.
I paste the relevant information below
J
15/04/2020 19:15:18criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2020 19:14:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2020 19:13:58criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2020 19:13:8criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1427000000640256 qam37
22670000009.140256 qam17
32750000008.940256 qam18
42830000008.440256 qam19
52910000008.540256 qam20
62990000008.340256 qam21
7307000000840256 qam22
83150000007.940256 qam23
9323000000840256 qam24
103310000008.340256 qam25
113390000007.838256 qam26
123470000007.540256 qam27
13355000000740256 qam28
14363000000740256 qam29
15371000000740256 qam30
163790000006.840256 qam31
17387000000740256 qam32
183950000007.340256 qam33
194030000006.940256 qam34
204110000006.540256 qam35
21419000000640256 qam36
224350000005.540256 qam38
23443000000540256 qam39
244510000004.940256 qam40
1Locked40.3122123
2Locked40.383116
3Locked40.9112107
4Locked40.3108109
5Locked40.387115
6Locked40.3101102
7Locked40.9100123
8Locked40.3128109
9Locked40.3107113
10Locked40.385119
11Locked38.9109111
12Locked40.3112108
13Locked40.3115114
14Locked40.985123
15Locked40.9123106
16Locked40.3126114
17Locked40.398108
18Locked40.9114117
19Locked40.381119
20Locked40.3112116
21Locked40.3175115
22Locked40.3138115
23Locked40.9163109
24Locked40.3209115
1394000044.3512064 qam4
2326000194.1512064 qam5
3536999745.1512064 qam2
3ATDMA0000
BumbleVMTech
  • 718
  • 128
  • 212
Re: T3 and T4 timeout errors - slow speeds and occasional drops in internet
Hi, You only have 3 upstreams.  can you remove and check all cables.  Then do a pinhole reset by pressing reset button in for 20 seconds then releasing for 5, do this 3 times.  After this log back in and check for 4 upstream channels
Rich
Here to help! I'm a Field Technician helping out from home.
Find out more
REFER A FRIEND AND SHARE £100 BETWEEN YOU
****************** ASK ME HOW ******************
jkenti
Hi Rich
Thanks for your message - not really sure what any of the numbers etc mean, so I really appreciate it.
I have done as you suggested, disconnected all cables, reconnected them, pin reset three times.
I still only have 3 upstream channels (see below) - so still getting the T3 and T4 timeout errors.
Any further tips?
1603000075.1512064 qam1
2394000484.3512064 qam4
3537000315.1512064 qam2
3ATDMA0000
BumbleVMTech
  • 718
  • 128
  • 212
Can you PM me your account and Area reference.  Will have a look for you
Rich
Find out more
