on 03-04-2023 19:47
For the past month I've had a steadily worsening connection. It went from solid to a few stutters and then hours of downtime multiple times a day with nothing changing at my side. After trying to get help or even just acknowledgement from the Twitter 'help' I called. Had an engineer out on Saturday who took my old Hub 3, unneeded splitter and incorrect mains supply and replaced it with a Hub 4.
I had no problems on Saturday aside from what I thought were to do with the switch out. Unfortunately, Sunday and today I've had a steady series of brief connection drops that show up with lots of the following although mostly the first two.
"No Ranging Response received - T3 time-out"
"SYNC Timing Synchronization failure - Loss of Sync"
"Missing Mandatory MDD TLV on primary DS Channel"
"Unicast Ranging Received Abort Response - initializing MAC"
"CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A"
"Unicast Maintenance Ranging attempted - No response - Retries exhausted"
I can't understand why I'm getting this and I know I have zero hope of getting support before going crazy via phone.
"Have you tried turning it off then waiting a minute and turning it back on? Are the cables connected?"
I just can't do it. I know some people have simple issues, I'd love for it to be a simple issue but these errors tell me there's a pretty big problem. Can someone please help? I know there are support peeps around here.
on 03-04-2023 22:01
I forgot to set this up until today for the new IP. I did this around 1pm and this is how it's been since.
on 04-04-2023 10:04
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. The forum software will remove the MAC addresses for you (If you get an error - just click the 'post' button again).
on 04-04-2023 12:10
Doing this in a few parts because it keeps giving me errors about it being over 20k character when I know it isn't.
Item | Status | Comments |
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
Channel Overview | Downstream | Upstream |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
4 | 162750000 | 5.300003 | 40.366287 | QAM256 | 4 |
1 | 138750000 | 5.599998 | 40.946209 | QAM256 | 1 |
2 | 146750000 | 5.500000 | 40.366287 | QAM256 | 2 |
3 | 154750000 | 5.599998 | 40.366287 | QAM256 | 3 |
5 | 170750000 | 5.000000 | 40.366287 | QAM256 | 5 |
6 | 178750000 | 5.000000 | 40.366287 | QAM256 | 6 |
7 | 186750000 | 4.699997 | 40.366287 | QAM256 | 7 |
8 | 194750000 | 4.099998 | 40.366287 | QAM256 | 8 |
9 | 202750000 | 3.799999 | 40.366287 | QAM256 | 9 |
10 | 210750000 | 3.700001 | 40.366287 | QAM256 | 10 |
11 | 218750000 | 3.599998 | 40.366287 | QAM256 | 11 |
12 | 226750000 | 3.400002 | 40.366287 | QAM256 | 12 |
13 | 234750000 | 3.099998 | 40.366287 | QAM256 | 13 |
14 | 242750000 | 2.799999 | 38.983261 | QAM256 | 14 |
15 | 250750000 | 2.400002 | 38.983261 | QAM256 | 15 |
16 | 258750000 | 2.299999 | 38.983261 | QAM256 | 16 |
17 | 266750000 | 2.099998 | 38.983261 | QAM256 | 17 |
18 | 274750000 | 1.599998 | 38.983261 | QAM256 | 18 |
19 | 282750000 | 2.200001 | 38.983261 | QAM256 | 19 |
20 | 290750000 | 2.799999 | 38.983261 | QAM256 | 20 |
21 | 298750000 | 3.299999 | 38.983261 | QAM256 | 21 |
22 | 306750000 | 4.099998 | 38.983261 | QAM256 | 22 |
23 | 314750000 | 4.800003 | 40.366287 | QAM256 | 23 |
24 | 322750000 | 5.000000 | 40.366287 | QAM256 | 24 |
25 | 330750000 | 4.699997 | 40.366287 | QAM256 | 25 |
26 | 338750000 | 4.500000 | 40.366287 | QAM256 | 26 |
27 | 346750000 | 4.599998 | 40.366287 | QAM256 | 27 |
28 | 354750000 | 4.800003 | 40.366287 | QAM256 | 28 |
29 | 362750000 | 4.599998 | 40.946209 | QAM256 | 29 |
30 | 370750000 | 4.400002 | 38.983261 | QAM256 | 30 |
31 | 378750000 | 4.000000 | 38.983261 | QAM256 | 31 |
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
4 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.946209 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.946209 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
159 | 94 | 4K | 1800 | QAM4096 | 424 |
Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
159 | Locked | 42 | 3.2 | 362508189 | 0 |
on 04-04-2023 12:16
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 23600000 | 40.270599 | 5120 KSym/sec | 64QAM | 13 |
2 | 30100000 | 40.270599 | 5120 KSym/sec | 64QAM | 12 |
3 | 36600000 | 40.770599 | 5120 KSym/sec | 64QAM | 11 |
4 | 43100000 | 41.270599 | 5120 KSym/sec | 64QAM | 10 |
5 | 49600000 | 41.770599 | 5120 KSym/sec | 64QAM | 9 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
Channel | Channel Width (MHz) | Power (dBmV) | FFT Type | Modulation |
14 | 10.0 | 36.2 | 2K | QAM128 |
Channel | Channel Type | Number of Active Subcarriers | First Active Subcarrier (Hz) | T3 Timeouts | T4 Timeouts |
14 | OFDMA | 200 | 53.9 | 0 | 0 |
on 04-04-2023 12:18
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | kfoA,.iyewrkldJKDHSUBsgvca698 |
SFID | 24085 |
Max Traffic Rate | 143750047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 24342 |
Max Traffic Rate | 22000047 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 04-04-2023 12:19
Time | Priority | Description |
Tue Apr | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 4 | Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 3 | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr | 3 | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-04-2023 12:20 - edited 04-04-2023 12:28
Just noting the Thursday was the brief trip to 1970. There was also a lot of this on Sunday. Nothing (yet) since the big outage.
This was Sunday's graph from the very moment I set the BQM to the new IP.
on 05-04-2023 16:22
For an update after the big outage I'm still seeing huge latency spikes. I did try calling about this and was essentially told they saw nothing wrong with it because it hadn't dropped (yet) today / Wednesday.
on 05-04-2023 17:17
