auile17
  • 8
Message 1 of 16
Switch to 1Gig and speed only 400Mbps
I upgraded from 500Mbps to 1 Gig and speeds never have change. I have factory reset it several times, numerous call to customer support without any success. Im measuring speed with a ethernet cable (cat6) connected directly to HUB4. See below hub config and network values. No one in customer supports seems to understand or know how to fix this issue. Speed are tops 400mbps. NEED HELP!
auile17
  • 8
Message 2 of 16
Re: Switch to 1Gig and speed only 400Mbps
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
6.7
40.4
QAM256
25
1
139000000
6.2
40.4
QAM256
1
2
147000000
5.9
40.4
QAM256
2
3
155000000
5.7
40.4
QAM256
3
4
163000000
6
40.9
QAM256
4
5
171000000
6.1
40.4
QAM256
5
6
179000000
6.2
40.9
QAM256
6
7
187000000
6.4
40.9
QAM256
7
8
195000000
6.2
40.4
QAM256
8
9
203000000
6.1
40.4
QAM256
9
10
211000000
6.1
40.4
QAM256
10
11
219000000
6.3
40.4
QAM256
11
12
227000000
6.3
40.4
QAM256
12
13
235000000
6.3
40.9
QAM256
13
14
243000000
6.1
40.4
QAM256
14
15
251000000
5.7
40.4
QAM256
15
16
259000000
6
40.9
QAM256
16
17
267000000
6.2
40.9
QAM256
17
18
275000000
6.6
40.4
QAM256
18
19
283000000
6.4
40.4
QAM256
19
20
291000000
6.3
40.4
QAM256
20
21
299000000
5.4
40.9
QAM256
21
22
307000000
5.5
40.4
QAM256
22
23
315000000
5.7
40.4
QAM256
23
24
323000000
6.4
40.9
QAM256
24
26
339000000
6.4
40.4
QAM256
26
27
347000000
6.3
40.4
QAM256
27
28
355000000
6.1
40.9
QAM256
28
29
363000000
5.8
40.4
QAM256
29
30
371000000
6
40.4
QAM256
30
31
379000000
5.6
40.4
QAM256
31
auile17
  • 8
Message 3 of 16
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
40.366287
0
0
1
Locked
40.366287
0
0
2
Locked
40.366287
0
0
3
Locked
40.366287
0
0
4
Locked
40.946209
0
0
5
Locked
40.366287
0
0
6
Locked
40.946209
0
0
7
Locked
40.946209
0
0
8
Locked
40.366287
0
0
9
Locked
40.366287
0
0
10
Locked
40.366287
0
0
11
Locked
40.366287
0
0
12
Locked
40.366287
0
0
13
Locked
40.946209
0
0
14
Locked
40.366287
0
0
15
Locked
40.366287
0
0
16
Locked
40.946209
0
0
17
Locked
40.946209
0
0
18
Locked
40.366287
0
0
19
Locked
40.366287
0
0
20
Locked
40.366287
0
0
21
Locked
40.946209
0
0
22
Locked
40.366287
0
0
23
Locked
40.366287
0
0
24
Locked
40.946209
2
0
26
Locked
40.366287
0
0
27
Locked
40.366287
0
0
28
Locked
40.946209
0
0
29
Locked
40.366287
0
0
30
Locked
40.366287
0
0
31
Locked
40.366287
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
96
4K
1880
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
33
Locked
43
5.5
10329078
0
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
47.3
5120 KSym/sec
64QAM
5
2
53700000
48.3
5120 KSym/sec
64QAM
2
3
46200000
47.8
5120 KSym/sec
64QAM
3
4
39400000
47.5
5120 KSym/sec
64QAM
4
auile17
  • 8
Message 4 of 16
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
378724
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
378723
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Time
Priority
Description
Thu 01/01/1970 00:01:25
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/12/2021 18:24:35
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/12/2021 18:24:45
5
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/12/2021 18:24:59
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/12/2021 00:47:14
5
  • 6.1K
  • 512
  • 1.57K
Message 5 of 16
Wired or WiFi? 400 on WiFi is about right for some devices.
The stats all look okay btw.
jpeg1
  • 6.93K
  • 357
  • 1.28K
Legend
Message 6 of 16
OP says ethernet.  All the stats look good.
auile17
  • 8
Message 7 of 16
Wired as stated above with a cat6 ethernet cable. Im expecting to see at least 800Mbps wired in my computer which is reasonable for 1gig connection instead of 400
David_Bn
  • 8.66K
  • 363
  • 670
Message 8 of 16
Good Afternoon @auile17, thanks for your posts on our Community Forums and a very warm welcome to you!
Have you been able to perform anymore speed tests since your most recent post? If so, are you seeing a speed that resembles the speed you're subscribing to?
Kindest regards,
David_Bn
auile17
  • 8
Message 9 of 16
Hi yes i have tried it again, without success speed top out at 400 430 mbps with ethernet cable connected directly to hub4 in router mode
John_GS
  • 14.43K
  • 738
  • 1.35K
Message 10 of 16
Hi @auile17
Thanks for coming back to us. It needs raising with IT so I shall PM you now to assist further.
Best
John_GS
