neogen1000
  • 7
Message 1 of 10
Superhub 3 speed issues
9I've been having trouble with my broadband for a few days. I've only been getting 2mbps via ethernet cable and wireless on the superhub 3. I've tried the usual resetting the hub, pin hole reset, checking cables, etc the only time I get my usual speeds is when I reset the hub for the first 5-10 mins then it goes back down to 2mbps. Can anyone see any issues? I will post info below.
Tags (1)
neogen1000
  • 7
Message 2 of 10
Re: Superhub 3 speed issues
1227000000040256 qam12
22190000000.440256 qam11
3235000000-0.240256 qam13
4243000000-0.740256 qam14
5251000000-0.740256 qam15
6259000000-0.240256 qam16
7267000000-2.540256 qam17
8275000000-238256 qam18
9283000000-1.740256 qam19
10291000000-1.440256 qam20
11299000000-1.238256 qam21
12307000000-1.240256 qam22
13315000000-140256 qam23
14323000000-1.240256 qam24
15331000000-1.240256 qam25
16371000000-0.940256 qam26
17379000000-138256 qam27
18387000000-0.740256 qam28
19395000000-0.940256 qam29
20403000000-0.740256 qam30
21411000000-0.938256 qam31
22419000000-0.740256 qam32
23427000000-138256 qam33
24435000000-1.238256 qam34
1Locked40.340
2Locked40.350
3Locked40.340
4Locked40.300
5Locked40.300
6Locked40.300
7Locked40.370
8Locked38.940
9Locked40.360
10Locked40.350
11Locked38.650
12Locked40.950
13Locked40.350
14Locked40.300
15Locked40.330
16Locked40.300
17Locked38.950
18Locked40.340
19Locked40.350
20Locked40.360
21Locked38.900
22Locked40.360
23Locked38.900
24Locked38.900
neogen1000
  • 7
Message 3 of 10
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14620000048.3512064 qam1
23940000047.8512064 qam2
32579992747.3512064 qam4
43260000047.5512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
neogen1000
  • 7
Message 4 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID469570
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID469569
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
neogen1000
  • 7
Message 5 of 10
Cable Modem StatusItemStatusCommentsAcquired Downstream Channel (Hz)
227000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 10
Do you have any Powerline Adaptors (PLA) or suchlike in your Local Area Network (LAN) ?
While you are waiting for the BQM to develop can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
neogen1000
  • 7
Message 8 of 10
https://www.thinkbroadband.com/broadband/monitoring/quality/share/72965ac9efd8999f14c17cdc233a4b4429d97667
Here is the link and no I don't have any powering adapters
neogen1000
  • 7
Message 9 of 10
My BQM
Natalie_L
  • 2.65K
  • 120
  • 229
Message 10 of 10
Hi neogen1000,
Thank you for posting your findings.
I have ran some checks from our side and we would need to look in to this matter a little further.
This may require a technician visit but I need to confirm if you would be happy for us to arrange this for you?
If you let me know, I will go ahead with scheduling in the visit.
Nat
