cowyed1
SuperHub 4 Slow Wired Connection
Hey folks,
I've just moved to a SH4 from a SH3 and I'm getting fairly poor download speeds with wired connections (wifi seems fine, which is odd). Previously on the SH3, I was getting ~520Mbps, now with the SH4 I am getting ~400Mbps. The SamKnows real speed test says I am getting a gig to the hub, but the ports seem to be the bottleneck.
I've tried different ethernet cables, different wired devices and a pinhole reset with no change. Engineer came out to have a look today and it felt like I knew more about the SH4 than he did (which he admitted, to be fair. One day's training!!).
Anyone else seeing this?
Cheers
Cowyed.
Wasbot
  • 8
Re: SuperHub 4 Slow Wired Connection
I received my Hub 4 a week ago.  Installation seemed to be no problem but now I'm getting slower wired speed on the Gig1 service that I did on my Hub 3 & 350Mbps service.  At the moment the average wired speed is about 200 to 250Mbps.
I've tried Cat5e, Cat6 & currently cat7 cables without any change.  I usually have the hub in modem mode and use my own router, a TP-Link Archer AX11000.  Even after a pin reset and the Hub 4 direct to my PC, it's still only marginally faster, about 200 to 300Mbps.  My mobo has two gigabit LAN ports.  Both return the same speeds.  I've updated the drivers and forced the port in 1000 Full Duplex.  No change.  Disabled my AVG, increase of about 50Mbps if that.
To rule out whether it's my PC, I've also hardwired it into a Dell 3510 that has a gigabit LAN port.  Exactly the same directly from the Hub 4 in modem mode or the straight after a PIN reset with the only change being a password reset to the Hub 4 itself.
I've scoured the internet for similar issue and possible fixes.  Tried with QoS on and off within the LAN port driver, no change.  Disabled & re-enabled the WIndows Autotuninglevel, no change.
I've had an engineer to the address.  Unfortunately, he hadn't had any training and admitted it was the first time he'd seen the Hub 4.  After another pin hole reset, the Samknows realspeed test confirmed 1086Mbps to the Hub 4 but still only 200 to 250Mbps to the PC through the wired connection.  The WiFi to a phone was topping around 380Mbps.  The engineer called another engineer who told me he'd had the same issue and to reset the Hub.  As you can imagine, seeing as it has been done multiple times already, no change.  The engineer didn't have another Hub 4 to test and left as he could prove the full speed to the Hub 4.
Calling VM is absolutely painful.  After three hours or more of being passed around and cut off several times, being promised the 'specialist team' who are trained on the Hub 4, even though they seem to follow the same script, still can't help, I'm left with worse speed than I previously had.
I may be missing something plainly obvious but I'm at a loss.  The general idea seems to be that if the speed is hitting the Hub 4, then it's my equipment.  It very well could be but I find it odd that three gigabit LAN ports across two different devices, the laptop also having a fresh Win10 installation on it, are all in the same 200 to 250Mbps region.  It seems too coincidental to me.
Where I go from here I have no idea as VM don't appear to have any suggestions.  The engineer promised he'd follow up once he'd spoken to some colleagues and would call back with another Hub 4 to test.  No surprises that I haven't heard a word from him.
Any suggestions for something to try would be welcome.
Cheers
Was
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
@Wasbot wrote:
If you want assistance please start your own thread.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Gareth_L
  • 6.19K
  • 379
  • 676
Hello cowyed1
Thanks for your post
Sorry to hear the service is still hit and miss
I have had a look at th signal on your hub and one of the downstream and upstream levels are missing
Can you reboot the hub
One you have done that let me know, if its still an issue after that.
I would need to book an engineer out
Gareth_L
cowyed1
Not sure what has happened since I first reported this issue, but I am now getting ~750Mbps through my wired connection. I see there has been a firmware update sometime around May/June and I'm wondering if this is the cause of the improvement. I also had to do *another* pinhole reset because whenever the router reboots, it takes a minimum of 3 goes before it gets a connection to the cabinet in the street.
I wouldn't recommend the 1Gbps package just yet unless you like to live on the edge!
